FlyBieWire
Member
- Apr 18, 2006
3BCat said:The advent of small jets into the national airspace system has shifted commuter traffic from the upper teens to the upper twenties and higher flight levels. It pays to have more altitudes that are usable because more aircraft are in use. Transatlantic/International traffic is also up, so RVSM makes good sense for these operations, too.
some_dude said:Why is it necessary? So Boeing and Airbus will sell more new airplanes, and so a bunch of avionics manufacturers and shops will make money!
My question is: Why is this true.srjorion said:The higher you go, the less accurate barometric altimeters are. That's why there used to be a 2,000' split above FL290.
2000flyer said:RVSM has nothing to do with who sells what. Its a capacity issue. Allowing reduced separation both vertically and horizontally means more aircraft in a given piece of airspace, plain and simple.
Lrjtcaptain said:Vertically, absolutly, the NAS was wasting so much sky by the 2000ft rule, especially with the increase of RJ's out there.
As for horizontal....well, find me a center that is running you inside of 5 miles at the same alititude. Negative!
hence. REDUCED VERTICAL
FlyBieWire said:Can anyone explain why RVSM is necessary above FL 290. What is so special about those higher altitudes?
Lead Sled said:Now about those TAFs and METARs...
'Sled
some_dude said:I'm sorry, but I'm not buying it. In the North Atlantic, sure. Central East Pacific, sure. Europe, even.
But the US? Give me a break. RVSM in the US was done because of pressure from the Europeans, and so the FAA could feel like we are not inferior to the French.
Check 6 said:We need more runway capacity!
2000flyer said:So are you saying let the rest of the world accept a certain standard but we in the U.S. are too good for someone elses idea? It's no wonder with an attitude like that we're frowned upon in parts of the world.
Secondly, the rest of the world accepts the new standard but since we don't we'll be severely limited in where and when we can operate around the globe. Worst yet, those operators who wish to comply will be burden with a much higher cost.
Sometimes change is good and others have a pretty darn good idea. Would you feel better if it were an American idea and the rest of the world had to comply?
Yes, having to jump through all the hoops to comply is a burden and the paperwork over blown.
