Why do some people fly 747 patterns
because they think they are a 747
Some pilots have it in their head that a tight pattern increases their chances of a base-to-final spin. They don't fly that often and want that extra time to think about what they are doing.
OR, they just wanna play big airplane driver.
Flyin Tony said:
Why do some people fly 747 patterns in there little cessna?
Because the controller said to extend downwind and forgot about us after landing all those regional jets.
My guess is CFI's start everybody out doing it and ATC demands it sometimes.
That's what happens when you put a pilots uniform and epaulettes on these 10 hour wonder pilots.
You can't have a base to final spin, if you don't have a base to final stall.
Stall speed doubles with bank angle if you're pitching to maintain altitude...if you teach your students to let the plane do two things at the same time, they wont stall. No stall, no spin.
Or you can do what I did this morning, and forget that I switched out airplanes in BHM to a baron from a van, and hit abeam at 210 and clean, and realized that it was gonna take me some time to slow down. (End of a 14 hour duty day, no wisecracks please! HAHA)
But it is fairly easy to stall the lower wing in a skidding turn if too much rudder is used. Some guys that don't fly very often aren't too worried about being coordinated in the pattern, as they are more focused on lining up with the runway (I am talking the occasional weekend flyer, not a student).
Too much rudder in a skidding turn and you will end up inverted at 400 agl.
To piss you off.
Why do people post stupid questions like this?
So, it would be easier to teach students to use half a county to turn an airplane, than it would be to teach them to not "skid turn" an airplane?
You must mean "200 and clean". 210 gets you a ticket in the Class D.
Yea thats what I meant!
I meant to say 200
Negative. If (and when) I am able to teach students in the future, obviously the objective is a square and close pattern with coordinated turns. The wide pattern I was refering to is typically flown by weekend guys who only see an instructor every two years. They don't care what other pilots think, just as long as they feel comfortable (I have flown with a guy like this). There is no way to change their bad habits until BFR time comes around, and even then you only get an hour or so in the plane with them.
During a checkout at a local FBO a few months ago I had a CFI tell me my pattern was "uncomfortably tight." The airport is right in the middle of a populous area, and my thinking was I wanted to know I could put it down on the runway from just about any point in the pattern if I had to. For the remainder of the ride I kicked it out to where he was "comfortable." I tend to fly a tight pattern, but that's how I was taught. I think it all comes down to how one learns. If private pilots are flying huge patterns, its because someone taught them to.
Heyas,
Back in the early Cretaceous when I learned to fly, it was standard to fly a pattern where if you lost your engine, you could still make the field. Since I learned at a place where it was surrounded on one side with DENSE urban development, and on 3 sides with some of the nastiest, muddiest water this side of Bangladesh, everyone had a vested interest in doing so.
Somewhere along the line, the FAA decided that too many pilots were trying to fly patterns too tight, and some number cruncher figured out that there were more fatalities/injuries in stall-spin accidents in the pattern than people losing engines in the pattern, so the FAA changed their "guidance" sometime in the 1990s.
From a pilot perspective, I agree. Keep it in where you can make the field and reducing the size of the pattern means less time in the pattern, which also means less chance of a mid-air or other problem.
On the other hand, if Joe Cessner and Polly Pretty Pants Piper can't manage their airspeed properly in the pattern, maybe its best.
Some take it pretty far, though. I flew a bit out of Homestead (X51), and the local CFIs fly patterns for 9 so far out that there is NO way that they'd hit dry land if they lost one. They'd be battlin' the gators out in the swamp. I swear they fly out for a 3 mile final, and they don't start descending until their turn final.
Nu
NuGuy said:
Heyas,
Nu
Sometimes I bitch when I get stuck behind the B52 wannabes, but man... looks like it can get much worse.
FN FAL said:
...Stall speed doubles with bank angle if you're pitching to maintain altitude...
Stall speed increases as the square root of the load factor. Load factor increases as 1/(cos(bank angle)).
For example: a 60 degree bank gives a load factor of 2. The square root of that is about 1.4. Therefore your stall speed increases by a factor of 1.4.
