Which tests for the Delta interview?
PapaSiera
Which tests are they still using on the Delta interview? I see in the WFFF gouge that there are
the
-- Job knowledge test
-- Job knowledge situation test
-- Mechanical Comprehension
-- Verbal Comprehension
-- Verbal Reasoning
-- Math Test
-- Cog test
From what I have been reading it looks like just the job knowledge test now.
Whats the best way to study for that? I was looking through the ATP written, and a lot of those types of questions were not in there.
Just looking at the gouge, it looks like a hell of an interview to study for. Any suggestions?
Here is a good link to a place where you can study for the cog test.
http://www.lumosity.com/
if you do that for a few weeks you should be good to go.
bro, I wouldn't spend too much time studying for the cog test; as long as you don't blow it off you should be OK. Recommend you spend the lion's share of your prep with the job knowledge test; from what I understand, some of the questions have been changed, although it supposedly remains conceptually close to the gouge. the interview process is more in-depth than some, but by no means should you be overly intimidated.
