jergar999 said:
The Metro would almost always show the same rate of climb at 140 and 180 KIAS.
Not to sully a dang fine thread (thanks for the fantastic post, GV), but I have myself an idear:
This was demonstrated to me in a King Air 200 by a 757 AA CA. He spoke for literally ten minutes straight, saying this is a perfect piece of information which, when used, separates the pilots from the aviators.
He kept calling it L/D Max, L/D Max... I understand the drag curve and performance, and where you can get the dreaded bimodal distribution (you get the same climb at two speeds), but there is no free lunch in physics. Those two humps will come together at some regime.
My question (BBB or GV or any other Carl Sagan Gene. E. Yuss) is this: What is the key to causing this? It happens on a 757, it happens on a Metro, it happens on my Dash 8, it happens on BE20s.
L/D Max with TWO humps (local maxima, makes sense, just a bit o' caculus... ) but what be the variables that are germane to just this behavior?
FWIW: You can get THREE speeds with exact rates on the Dash8 100- it depends on how much you rely on deck angle for climb versus airspeed and how dense the atmosphere is (125kt, 160, and 192/3Kt get you 1000' fpm until about 5000 feet, and the high number decays to maintain the rate until meeting at 160 around 10-12). But wait- I thought we clumbed up there because of excess thrust? Is it parasite drag curve over an induced drag curve ALL under the excess thrust available, with the vector of thrust boogering up the numbers and creating the very low number, or do the forces involved just magically mesh?? Or do I need to have a glass of STFU and play pilot in my little trash 8 and forget about it?
**Gee, the answer is right in front of me. Buck-60 is the profile for climb, usually getting 1000 or so... The magic number seems to be +/- 35 knots or so and that's where the neat stuff happens. Makes a HUGE difference if you're flying the wrong way on the initial departure (SLOOWWW GS), or if you're in a hustle doing a parabolic to get home early.
