What is the strongest wind you have flown in?
260/38G58 at MDW landing 31C. Had several days with gusts in the 50's in many places. Always fun. Aloft? Mid to 100's I guess in the 30's or 40's...?
91 said:
but we lucked out and the touchdown wasn't all that bad.
I know I've made some (lucky) greasers with gusty x-winds. I'm sure from the pax view, it looked like a monkey f-in a football.
Now I've managed to slam a few with not a trace of wind.
Landing: 30G45 45 degrees from runway on a 1600 ft dirt strip in Alaska in a C206.
Flight: Just the other day had 110 kts on the nose at FL340. Indicating 240KTS over the ground. A Delta MD90 passed 1000 feet below us going the other way and my first thought was "Lucky bastard!"
PureMuscle said:
A lot of you have seen 40+kt crosswind. Whether it's direct or not, that's still a lot.
I'm going to have to call BS on some of these. Perhaps they are talking about crosswind component, but most GA aircraft are only certified to 15-20 knots direct X-wind and most jets 25-35 knots, so anything above that says that we have quite a few test pilots (meaning flying well beyond the limitations of their airplanes) on this board.
Anyway, the best I've seen is 30G50 on landing and 175 in the jetstream.
Dont know about these other guys but as far as the lear is concerned the X-wind conponent is NOT a limitation. It is a DEMONSTRATED X-wind component. No mention of it as a limitation.
Johnny
T-Gates said:
Exactly.
Probaly the biggest misconception in aviation.......
Now some airplanes have a maximum crosswind limitation when certain systems are inop, or under certain runway conditions, but that's a different story.
You are right. Didin't mean to put the L word in my statement. All I'm saying is when you exceed the maximum demonstrated x-wind component of your airplane, you are a test pilot. Now if the landing goes well then no harm no foul, but if it doesn't, you've got nothing to defend yourself with.
I've exceeded the recommended x-wind component many times. However, it's only been in planes I'm very comfortable in, and I always plan on a go-around if I run out of rudder. I also aim for the upwind side of the centerline in case I get pushed.
Now if I could just get that same feel for the EMB, I'd be very happy.
The best I have seen aloft was a tailwind of 210kts going across the North Atlantic that gave us a ground speed of 680kts. You no sooner got the HF mess overwith at 40W and it was time for another one at 30W.
That oughta help the weathervane effect once you are on the ground.:rolleyes:
I think I'll let the test pilots keep the "demonstrated" records.
I don't think exceeding the demonstrated x-wind component makes you a test pilot. All the test pilots do on this is demonstrate the x-wind component on a given day. It was never meant to be a limiting factor at all. I don't know that they could ever determine the maximum. The limiting factor is the rudder. The demonstrated component should give you pause for reflection if you aren't experienced with x-wind landings under strong and gusty conditions.
I've been told the reason they don't go any higher than 20kts or so is for liability purposes, not because the aircraft can't do it. When you're out of rudder, better have a plan B.
I do. And if you continue to exceed max demonstrated crosswind landings, you just might determine one. If you never want to discover the maximum crosswind limit for an aircraft, don't exceed the max demonstrated. It's a pretty simple concept, really.
Landing in Buffalo during the wind storm in November 2003. Perfectly clear day, beautiful actually, but winds 20 degrees off the runway at 43 G 56. Rough as **** below 1000 ft too. It worked out OK but I wouldn't do it again.
In flight: 210 kts at FL370 over NM. It was a tailwind thankfully. GS was 660 kts.
direct x-wind 28G41 in a Arrow IV.
There is an interesting article which I could not get to paste here, but you can look it up on www.flightsafety.org/alar/alar bn8-6-wind.pdg
The maximum demonstrated crosswind published in the approved airplane flight manual (AFM), aircraft operating manual (AOM) and/or quick reference handbook (QRH) is the maximum crosswind component that was encountered and documented during certification flight tests or subsequent tests by the manufacturer.
The wind value is recorded during a time period bracketing the touchdown (typically from 100 feet above airport elevation to when the airplane reaches taxi speed).
For some aircraft models, if a significant gust is recorded during this period, a demonstrated gust value also is published.
The maximum demonstrated crosswind;
1. is not an operating limitation (unless otherwise stated);
2. Is not necessarily the maximum aircraft crosswind capability; and,
3.generally applies to a steady wind.
Much more information is included in the article.
Of course the crosswind capability is affected adversely the several factors.
The Westwind for example has a demonstrated component for the Westwind I of 20 kts. The Westwind II is 23 kts. No major differences in the two aircraft. So if you fly the westwind 1 at 23 kts crosswind, you have not become a test pilot. It was never meant to be a limiting factor for design purposes, thus it is no different than climbing out @ 15 kts over recommended climb speed.
In fact it could be that a crosswind of far less than maximum demonstrated is extremely risky on an ice covered runway.
I've seen gusts to 50 a couple of times, and f-ed it up everytime. After the landing the x-wind from the Capt. was even worse. It wasn't really that bad.
I don't get out much.
The messiest for me so far was taking off and landing at ONT (8R) with the Santa Anas blowing 020@45 gusting to 58 in a little jet. Yeehaw!
I'm surprised your airplane let you land. I'm not saying that in a mean way. A few years ago the wind was over 70 knots in PIT and the airport closed for arrivals. When it re-opened we popped over from Dayton and it was still 40 gusting to 56, pretty much right down the runway. We landed okay in a 737 but watched two Airbii go-around during the taxi in. Arriving at the terminal we noticed not an Airbus in sight, only Boeing and Douglas products. Something about ground speed min in the Airbus that causes a problem in those situations ?
TP
Sustained tailwind at FL 370 165 KTS on Thanksgiving Day a few years ago, DFW-ATL. Landed 25 minutes early, only to find the gate occupied. Did the "elephant walk" around the ramp three times, ended up blocking in 15 minutes late. . . . . . Defeat, snatched from the jaws of victory. . . . . Atlanta style!
Worst winds . . . . couldn't say for sure, but as a newhire, a 60 knot direct tailwind on the ILS that changed to L&V over the numbers was a memorable event . . . . silky smooth landing on a wet runway, though.
Unbelievable
49kt gusts 70 degrees off runway centerline while in heavy rain on ILS landing southeast at Sarasota, Florida in a Piper Arrrow. Landed and taxied in, thought about the experience later- WOW
Santa Anas
I Was doin' touch and goes in my cub the other day with 65knt cross winds. No problems. My dirty rolls that I was doin' just after take off were kind of sloppy though.........but I guess that sort of thing is what sets apart the men from the boys*
*Disclaimer to the cheesedicks on this board w/o a sense of humor: this is a sarcastic statement.
180kts crosswind this past winter at FL410, doing the east coast shuttle, somewhere northbound over the carolinas. I did have 160kts direct tailwind the day earlier, Austin to Boca Raton.
