hortonhcci
Member
- Jan 25, 2005
avbug: (sorry, I don't know how to paste pieces of earlier responses in here)
Backing up there just a little bit...you're building a piston jet engine? Is that like a reciprocating turbine? Or a reticulated fetzer valve? Or is it merely a jet engine that is built of free piston parts; the ones that don't cost anything? Where do you put the piston in a jet engine? Or does it just float around in there, hence it's title; free?
Yeah, it's truly free. The piston is attached to nothing at all. It's called a free-piston gasifier. All it does is generate a flow of hot exhaust gases which serve as the working fluid for the power turbine of a gas turbine (if you choose to put a power turbine in the stream). Otherwise, you just use the exhaust gases as a jet, which is what the original designer did.
