Used Air
Going into ATL you often end up doing your own finessing of the "in-trail", using the TCAS to gauge the guy ahead and behind, knowing what they are flying and what airline they are flying for. . . . if it is a heavy, you are going to keep it on the 4-5 mile range of the TCAS, if it is a similar aircraft, you will be looking at 3-3.5 miles.
Watching the guy in front and behind is going to govern when you transition from the "to the marker" speed to your final approach speed. . . . Gaining on the heavy? Get dirty early and transition to cross the marker at approach speed. The guy behind eating you up, and a "company" ahead of you? Keep your speed up a little longer, start slowing over the marker. Doesn't sound like much difference, but it is the difference between getting rocked and/or making the guy behind you go around.
Some airlines tend to roll it to the end, so you have to allow for that, too. Not sure why they would do that on a 10,000 ft runway, but it seems to be pretty common for certain carriers, who wil remain nAAmeless . . .
I have gotten rocked behind heavies, and don't enjoy it much, but the greyer heads like to call it "used air" and don't sweat it as much as I do. . . . . Coming from a bizjet, though, I have a very healthy respect for that "used air".
