nosehair
- Sep 22, 2003
Vmc Demo Recovery
Here's a different twist on the recovery technique:
I teach recovering as if you were having an engine failure on take-off. Reduce throttle on the operating engine AND lower the nose ONLY enough to regain directional control with a minimum loss of altitude. Imagine that you are trying to clear an obstacle at the end of the runway with an engine out, and you begin losing directional control. Pull the throttle back slightly, while lowering the nose slightly, and you will discover that you can regain directional control and airspeed while leveling off slightly. In most cases, throttle reduction to 65 - 75% power and nose down to a slight climb angle will produce a flying aircraft. This technique may allow you to maneuver around or over an obstacle on climb-out.
I also teach stall recovery with a very minimum loss of altitude.
Most students recover from stalls by diving excessively to regain excessive airspeed because they are recovering at an altitude that will allow that. Then, when they actually stall one on a go-around or high flare/bounce, they slam the throttle forward and punch the nose over into the ground - just like they have been rotely trained.
Stalls, Vmc Demos, Engine-cuts, all these things should be responded to and recovered from as if you were within a hundred feet of the ground.
