shamrock
- Dec 15, 2001
I almost hit a nice big mesa using this technique.
Was it one of those America West/USAirways 90 seaters?
Ding ding ding ding ding. We have a winner, folks.
Thanks.
Don't sweat the visuals. They will most likely not be a part of your 121 training. The circle to land is about the closest you'll get and you may not do it as an FO.
Visuals will come during IOE. They'll come hard and fast and every freakin Captain out there will want them done a little different. Screw them!
Fact of the matter is, if you are nervous about how to do a visual approach, you shouldn't be in a 121 cockpit. But hey, this is the world we live in.[/quote=buscap;119874]
Say what? Visual approaches have been a part of every sim-based training I've ever done. As were circling approaches(even as an FO). And I disagree about the 121 quip, visuals in a jet when you've never flown one are kind of a numbers game until you've got a little time in type. And to make a pre-emptive defense: not all 121 guys have jet time, either.
Ok guys, here is the SECRETS
1 secret) Look at your ground speed ex: 360kts
Then look at your current altitude ex: 28,000'
Then look at the field elevation or your level off altitude ex: 1000'
Then look at your DME ex: 54 NM
take 360/60=6 miles a minute you are traveling over the ground, so this means the field is 9 minutes away. You have to lose 27,000' in 9 minutes which equates to a 3000'per min descent rate.
2 secret) Another technique is: Take the altitude you are at 28,000' take the altitude you need to get to 1000' get the difference 27,000' multiply 27 by 3 = 81, so at 81 miles out you should start a descent to establish a 3 degree glide path. For every 10kts of tailwind add 1 mile to the initiation. Ex: 40 kt tailwind the descent should be started at 85 miles. Also keep in mind runway direction. If it is opposite from your current heading then you can delay the decent. On the contrary, if it is the same direction then add 10-15 miles to the initiation of the descent
How fast do you descend??? Use secret 1 to get you descent rate
3 secret)Rule of thumb: 30nm from the field you should be at 10,000'AFE 250kts
15nm from the field you should be at 5000'AFE 200kts
If you are higher than this you have too much energy. If you are lower than this you have too little energy
4 secret) Final approach is the simple 3-1 rule ex field elevation 1000' you are at 8NM you should be at 3400' or 2400'AFE if you are higher than this you are too high if you are lower than this you are too low.
Descent rates on final take you GS ex: 140Kts divide by 2 = 70 add multiply by 10= 700, so 700 on you VSI will be you descent rate
Try it out tell me what you think. The FMS and Flight Director are great, but every pilot should have sound knowledge and application of these techniques beacause how else do you check the autopilot or stump the Captain next to you who has no clue how to truly understand how to fly???
How I use these techniques?
First for initial descent i use secret 2. This way I have it figured in my head what ATC is planning to do or not to do. If I see that my DME is inside of my 3-1 then I either pimp ATC for a descent or I realize my descent will have to be greater than a 3-1.
Second while on decent I use secret one to adjust my descent rates
third I plan my descent to be at 10,000 30NM 250kts
then 5000 15nm 200kt
fourth on final I use secret four backing it up by the ILS
All-
i'm hopefully going to be starting my first 121 ground school in a few weeks, and I had a few questions.
According to several good friends who are currenly flying jets, the visual approach is the hardest thing to do (according to my one friend it is comarable to a V1 cut).
My question is this. besides using the VNAV stuff (not sure on how that stuff works yet) is there a better way to stay ahead of the plane doing a VAP?
thanks for the advice,
Pilotguy143
It is very cool to be able to smoothly fly a CRJ 250 KIAS to the marker and touch down on speed and stable in the touchdown zone. You definitely have to think ahead of the airplane. Don't try to do this on your first one.
Is it possible to do this and meet "stabilized approach" criteria? For argument's sake let's say stabilized approach criteria is on speed (ref +5 - 10 KIAS), configured for landing, and engines spooled up by 500' agl.
Too much mental gynmastics. Im a little slow with numbers/formulas/calculations, id be way past top of decent at this point.
Looking out the window works well alsoBut when im flying a turboprop in the middle of nowhere, ive got room to play around with.
Nothing bugs me more than when I get on a commercial flight and the pilots throw the spoilers out for the descent then they level off and goose the power. This is an example of poor energy management and lack of airmanship.
Spoilers definitely help.
If you start slowing a mile or two outside of the fix you can even do it without spoilers, although you might have to go a bit high on the GS initially to slow.
Do you go up to front and "have a chat" afterwards....??
No I don't because being a passenger I have no real idea what the actual circumstances were, but when the kid with suglasses on top of his head comes out to do his walk around I get a good inner chuckle
I like to ring my own bell.
This is somewhat evident. The clear message is this:
the fact that this thread even exists shows that there are too many truly unqualified and incompetent pilots. They are coming out of places like Jet U and ATP and are out there endangering the traveling public with there sorry attempts to break into aviation without the experience needed to safely accomplish the job.
This may or may not be true....
The issue is... what can be done about it. When a Jet U. or ATP guy shows up to fly the jet.. the FAA and company have said he is good to go... How do you say no to that?
During IOE you may be able to with hold him/her, but too much of that and the powers that be will scurtinize the Checkairman cadre...
After IOE what is a line Capt supposed to do? Refuse to fly with him? Then the Jet U pilots classmate will come out to the jet....
