Visible Moisture
Thats why I said I make my own rules and over the years I've flown with dozens of pilots, world-wide, part 91 135 and 121, who do it all a little differently. No matter what manufacturers say about visible moisture or known icing, no matter what the FAA says via regulation or AIM recommendations, or what any other pilot says.......there's just to much of a wide range of situations where icing can happen. It happens even when it IS NOT supposed to happen.
You need to pump the brakes a little on this one ;) , examples please!!
At 3-1/4sm you wouldn't see a Boeing 747.
Actually, you really would. And will. And do.
I've flown with enough different pilots through the years, hundreds of different pilots,
So which is it? Dozens, or hundreds?
Thats why I use anti-ice all the time, I probably use it more than anyone I know. I have my own rules. You can't die and you can't get busted or bitched at for using anti-ice when you don't need it, thats for sure.
Clearly you have your own rules, as well as your own ideas, concepts, and quite possibly, your own alphabet or mathematics system, too. Not particularly relevant to the topic at hand.
However...yes, you can die, yo can get busted, and you can get "bitched at" for using anti-ice when you don't need it.
Anti-ice systems used when not needed can make their use ineffective when they are needed. Examples of exhaustable systems include the nose anti-ice on a learjet...use it and lose it. When the alcohol is gone, there's no more. TKS on a mooney or other aircraft...use it and lose it. When it's gone, the weeping wing is no more.
Use the boots when they're not needed, you not only wear out the boots and needlessly deform the leading edge, but can damage the boots, dependin gon the conditions. To say nothing of making them ineffective if used too soon.
You claim 747 experience, but still assert that anti-ice can be used any time without penality? You're not familiar with the potential for leading edge device damage, takeoff performance penalties, etc? Or the fact that wing anti-ice is ineffective with the flaps extended?
Nacelle and engine anti-ice robs power and bleed air, and can deteriorate takeoff performance. It's not "free." Use of anti-ice increases fuel burn. It increases takeoff distance, or can, and it can reduce climb, circumstance-specific.
Use of wing anti-ice or engine-anti-ice at the wrong time can cuase runback with refreezing aft of protected areas. Thus use of anti-ice all the time is inappropriate and potentially dangerous, too. Use of anti-ice when warranted, and when appropriate, yes. Use of anti-ice indisciminately based on your own "rules?" No. Not a good idea, not a safe idea, and inappropriate.
Even when flying in the clear with that temp and vis, its good to just hit the switch. Its free.
Actually no, it's really not...not a good idea, and not free.
Ok, I think I understand now. Disregard the manufacturer reccomendations and make my own rules. Got it!;)
Yes, I meant to use the recommendations, but then go a little beyond and make yourself a little more safe. Meaning use anti-ice before the recommendations would have you use it.
Ok just kidding. But my real question was not whether it was a conservative choice, but rather was it operating out of the reccomendations of the manufacturer. I think I have my answer. Yes it is conservative and would'nt hurt, but it was not required per FAA or manufacturer.
I think you should have used the anti-ice in that situation, it falls within all manufacturers recommendations I've ever seen. Less than 10c with visible moisture. At the 3sm mark, where your vis ended on that day, thats the moisture you're looking at. So there was visible moisture in your area that you can plainly see with your eyes.
You were at 5c, right? AI "on".
So, you're asserting that the air is as saturated at 3 miles vis as it is at 1 mile vis? Question, why concern ourselves with the vis at all? Your logic is flawed because on a clear day I can sometimes see moisture 20 miles away in a shower. Does that mean that because my visibility stopped there that I need A/I? the Feds and most manufacturers it seems all agree that when it gets to a mile or less, icing conditions are present. not before that. Conditions present in the sim as described in the original post do not, by technical definition, meet the criteria for icing conditions. He did the right thing. And sim instructors don't always, every day, every time, give the best advice. They operate in a different world with scripts and rehearsed scenarios.
That may be the FAA's definition, but if pilots just used that as a guideline, there would be an increase in icing related accidents. Icing in clear air with better than 1sm visibility happens all the time.
I agree but when it is about passing a practical test, using the FAA's own interpretation is the safest way to go. Nothing wrong with imposing stricter criteria when flying the line though, consistent with you company's FOM and the AFM.
only a pilot could turn "visible moisture" into a Phd dissertation
if you see yourself flying in moisture (clouds, water droplets on glass, etc) and its less than 10C, anti-ice on. Period, the end
NEXT TOPIC PLEASE
NEXT TOPIC PLEASE
It's not nearly so simple, and you've little need to be so dismissive of the topic. Misunderstanding both the definition and the cause and effect can result in loss of certification, and an unsafe flight operation. It may even result in loss of life, and certainly has in the past.
You aptly state that anti-ice should be on in the clouds...but the question at hand is what constitutes a cloud. Whereas the topic is flying a circling approach and not in the clouds, and not with water droplets "etc," then we are left with what you feel is a "Phd dissertation." More to the point, your dismissal of the matter hasn't solved a thing. Use anti-ice, you say...but the conditions in which you assert one should use anti-ice don't exist in this case.
The circling airplane isn't in a cloud, isn't in precipitation...which leaves your dismissive assertion exactly where?
If its as close as 5+ and 3 miles which is usually an esitmate anyhow (could be higher/lower), just run the anti-ice.
I know it sounds caveman-like but the difference between 1 mile and 3 miles seems fickle. visibility tends to fluctuate anyhow and that 3 mile can quickly turn to less than 1 in a hurry. i dunno. to each his own. 3 miles is quite marginal and most likely contains a good deal of moisture if the visibilty is due to clouds or fog.
some things just don't matter, like in a G550/450. Put the sw in auto and go about your business. go ahead and nit pick.
I'm impressed FIDO - 99% of pilots are such control freaks they simply cant accept that an AUTO function means anything or would ever work!
2 years before delivery of the 450. Until then, the debate continues.
On a serious note, thank you to everyone willing to have the discussion.
FWIW, several years ago I had a face-to-face discussion with an engineer from Allied Signal regarding TFE-731 anti-icing usage. He commented that the biggest mistake that they see pilots in the field make is that we don't use anti-icing enough.
Personally, in the DA-50 and DA-900 I use the numbers in the AFM - less than +10C, visable moisture and/or visability less than 1 mile. Recently Dassault gave us a lower temperature limit of -40C as well
LS
The 1 mile in fog has always referred to when you use nacelle anti ice on the ground. It has nothing to do with inflight.
Inflight if you are in clouds, precip ,visible mosture ,etc you need anti ice.
Of course the temperature must be at or less that the manufacture states, usually 10 C or less.
Yes...and the debate at hand is what exactly is the definition of "visible moisture".
Is it 1sm? 3sm? 5sm? 6? 8? Does the observed visibility need to include BR?
Some pilots have their thoughts, while manufacturers have theirs. What's the FAA's definition of "visible moisture"? I haven't been able to find one...
Sorry,I dont know the legal defintion.
But a good guideline on when to turn it on is if your landing lights are reflecting back and you are in the temperature range for icing.
You were "corrected", or busted? IF the instructor/evaluator can specify a value or provide guidance that says you have to have had EAI on, then I'd say he has a leg to stand on and you simply bank that info for later. But it sounds to me like his approach could have been more like "I'd use it because of xxxx in this case" rather than a directive stating that you were wrong for not using it.
Did you descend through that 3000' ceiling to get to that circling approach? If so, EAI probably should have been on and just left on unless RAT or whatever temp you use inflight exceeded your max value.
Another aspect of EAI is that high power settings associated with takeoff and climbout are much more conducive to engine icing than descent and cruising around at lower power settings. I'd bet that a G-IV doesn't require anywhere near takeoff or go around power for a circling approach, but a rejected landing or go around is something that you'd have to consider, and for that reason alone, I probably would have used EAI, given the surface conditions and the fact that I don't have a clue as to G-IV limitations. Incidentally, it would not have been required in my DC-8.
Either way, I stand with what I said up top: Unless you can be shown a set of values stating otherwise, being "corrected" sounds a bit overblown on the evaluators part (or overly sensitive on yours...:laugh:).
P.S. Chasmo was posting at about the same time. I agree wholeheartedly about using landing lights to help determine if I'm in "visible moisture". But, that's a technique, not procedure, and secondly, you were in a simulator, not in an airplane. Do newfangled sims these days simulate visible moisture very well?:confused:
No I was not busted. I was debriefed by my sim partner that I should have used it and the instructor agreed. I agreed that it would not have hurt. But he took it a step further and said I was operating outside of the manufacturers reccomendation. Therefore stating a case that it (I) was dangerous. I did use EAI on the approach until I descended below the bases at which point I called for it to be off. One major reason I called for it to be off was that my landing data in the FMS was not computed to include EAI. And yes, if I went missed and had to go IMC I would have turned it back on.
I have never heard of anything other than visibility less than one mile being the definition of visible moisture. Seems this guy was giving you his opinion rather then the actual limitation.
No I was not busted. I was debriefed by my Sim partner that I should have used it and the instructor agreed. I agreed that it would not have hurt. But he took it a step further and said I was operating outside of the manufacturers recommendation. Therefore stating a case that it (I) was dangerous. I did use EAI on the approach until I descended below the bases at which point I called for it to be off. One major reason I called for it to be off was that my landing data in the FMS was not computed to include EAI. And yes, if I went missed and had to go IMC I would have turned it back on.
Glad you gave a better explanation of the Sim profile. To me your answers is your both right.. I do what you did all the time in those conditions. Whats with Sim partner being a critic.. tell him to keep his month shut till your out of the debriefing room...
If in doubt... use it... It is free to use (assuming you don't need the power)
