VFR Clearance
If you are VFR in class C, you aren't getting a clearance, per say. You are getting flight following and traffic advisories. You just happen to be calling clearance delivery to get a heading after takeoff, an altitude, a squawk and a departure frequency. It is all advisory in nature.
Now, if you are taking off from a class B airport, then you need an actual clearance to do so, which as we all know is not advisory in nature.
Timebuilder said:
I only had one unusual experience with a VFR clearance.
I flew out of RDU with someone in a Tomahawk in the same time frame and didn't have any problem.
Did you use the term "VFR Clearance"? If you did, maybe you confused the controller? You may have hit on a trainee who never came across it. Although we're using the term to apply to departure instructions from a Class C, it's really a misnomer. It's not standard terminology for anything having to do with Class C airspace and (except when used with the word "special" in front of it) doesn't appear in =any= FAA publication that I'm aware of. Truthfully, although I figured out what was meant right away when it was used in this thread, I've never heard the term before, not even in Class B. I can see someone (new) at ATC getting confused by the non-standard and pretty much meaningless phrase.
If that's it, then chances are that if your CD transmission was simply. "Raleigh Clearance Delivery. Bugsmasher 1234X at JetCenter. VFR Beaufort" everything would have been fine.
Midlife
From FAR Part 1-
Air traffic means aircraft operating in the air or on an airport surface, exclusive of loading ramps and parking areas.
Air traffic clearance means an authorization by air traffic control, for the purpose of preventing collision between known aircraft, for an aircraft to proceed under specified traffic conditions within controlled airspace.
And, again when VFR, do you call CD at a non-towered airport if there's a CD frequency for it?
If I was departing VFR and my route would take me thru other controlled airspace, I would. CD controller will advise on further action. If I am departing VFR but staying in local pattern, I would not.
Midlife, what would YOU do? What exactly are YOU teaching your students to do?
Re: Midlife
1. Departing Class G or Class E surface area VFR. There may be one, but I have difficulty imagining a situation in which I would call or teach a VFR pilot to contact a ground-based Clearance Delivery position.
2. Departing Class D. Again, unless advised by something in an ATIS broadcast of A/FD note, I would not call the Clearance Delivery position. Of course, I would call ground and Tower in the proper order.
3. Departing Class C or B, unless advised to the contrary in an ATIS instruction or A/FD note, I would call the Clearance Delivery position.
4. If departing from Class G, E or D (again in the absence of an ATIS or A/FD note to the contrary), if my route would take me thru controlled airspace that requires communication or a clearance, I would call the appropriate facility (usually Approach Control but it could be an enroute Tower) prior to entering the their airspace.
I didn't say "VFR Clearance" specifically, it was more like "VFR Northbound on a so-and-so heading at 3,500".
I thought I might have found a trainee, but I sure wasn't going to suggest that possibility on the radio!!!
Clearance delivery
If I see a freq for clearance delivery when I look in my A/FD, I call clearance. If I don't, I call ground. Of course all these freqs' availability hinges on the hours of operation (also in A/FD).
I can't imagine going anywhere without the little green book. It's as much a requirement to me as fuel.
thank you
FLyingwildfires
thank you, thats what I tried to post earlier but my transmission was not heard
oh well
Re: thank you
satpak77 said:
FLyingwildfires thank you, thats what I tried to post earlier but my transmission was not heard
Heard yes. Accepted, no. Neither of us is likely to convince the other.
I wonder - how many pilots out there train out of a plain vanilla Class D airport (with a CD frequency) and are taught to contact CD before every VFR departure?
The school I goto is located at a Class C airport (Oakland International) which has a overlaying Class B airspace above it. When we depart VFR we simply just call Ground, and never have we been asked to call CD for VFR ops.. however ground does want to know where we are headed and what kind of aircraft we are flying. In response GC will give us a heading, or direction to fly, altitude to stay below bravo, and squawk code. I cant recall them giving us a dep freq but then again they may just assume we know it. Just my .2 cents worth.
Ryan
Am I missing something?
I hope if I am missing something, then someone will line me out. I have always called clearance if there is a Clrnc Del freq in the A/FD, and the hours of operation apply. I do NOT call them if the ATIS carries a note to contact ground in lieu of clearance delivery, or carries some other pertinent instruction. I have taught all my students this way as well.
I do not skip Clearance Delivery even when I am on a fire dispatch, in which case I get the ATIS, call clearance, then ground, etc., etc., telling both clearance and ground I have a fire dispatch. They have been wonderful everywhere we work, at getting us out and on our way FAST... my point here being, we don't skip it, even when we are racing to the fire........
We have worked from Class B airports, all the way down to landing in glorified gravel pits, and I would hope like h#ll I am not doing anything amiss in terms of dealing with ATC, at each of these levels. I try to meet them in person when we are assigned to a certain base, and I call them on the phone if I can't meet them in person, in hopes of making both their lives and mine a little easier when it's all burning and gets smoked in. Please, tell me if I am missing something.... Thanks much.
