• Major updates to Logbook Pro for Android and APDL - Airline Pilot Logbook for 117 are now available. Minor update for Logbook Pro on iOS devices. Click to learn more: APDL 11, Logbook Pro for Android, Logbook Pro for iOS. Update your devices today.
VDP vs PDP
bertengineer
AM Aviation
Total Time
@ 5000
What is PDP. I am looking at questions from interviews and noticed this question. What is it?
Doc Holiday
Total Time
>1000
A PDP is a 'planned descent point', also referred to sometimes as a TTS (time to see)point. Several airlines use the concept and it is discussed in the book Mental Math for Pilots. A VDP is published on approach plates and take obstacle clearance into consideration, PDPs are 'calculated' by the pilot to simulate a VDP. This gives the pilot a good reference point to start a descent that will result in a 'normal landing' (reference 91.175).
I discussed this in an earlier thread, I'll see if I can go back and find it.
http://forums.flightinfo.com/showthread.php?t=58115
Hope this helps.
Crew-Member
Total Time
5 Logs
Doc Holiday’s answer is probably what they are looking (especially if used in connection with VDP).
It is also used in other aviation contexts: Power Distribution Panel (electrical system) and Pre-determined Point procedure used for fuel planning.
