User Defined DME-ARC on the GNS-XLS ?
satpak77
Marriott Platinum Member
Total Time
5000+
Ok, I admit I am not a certified factory tech rep on the GNS-XLS.
With that said, can the device (and if it can, please tell me how to do it) fly a pre-defined DME ARC off a user defined waypoint via autopilot?
For Example, lets say I want to orbit a 5 mile arc off a waypoint, located on the LAX 120 radial at 35 DME. I would defined that waypoint as LAX*35 (my personal method) in the box. Now, how can I fly a 5 DME arc around it via autopilot? (I know how to bring the course pointer up and fly it manually!)
Or say a manual lat/long waypoint entry, your girlfriends house is at XXXX North YYYYY West, now how can I orbit a 5 Mile arc off that?
DME Arc, not a holding pattern, just to clarify.
Can this be done?
TMMT
Total Time
Alot
Okay, I'm sure I'm missing something so please bear with me, but wouldn't you just define your way points along the arc fix/dist/radial and set your waypoints about 10 radial degs apart and then couple the AP to fly the route fix to fix?
