AAflyer said:-7s, WOW. I had flown -9s out of MIA hot and heavy on 9L. I swear I saw people's faces in the cars on Lejuene RD we were so low. Can only imagine if we had coughed an engine. YIKES!!
AAflyer
trainerjet said:AAflyer,
I'm surprised you take anything the "clownpilot" has to say seriously. A cursory examination of his posts should tell you that he either thinks he is being funny or just wants to start some sh!t. Either way, he contributes nothing worthwhile to this board and (along with a handful of others) is at the top of the IGNORE list.
AAflyer said:Not sure what the hell my post has to do with you not using reverse thrust. I was talking about -9 and -7 engines, how underpowered they are.
As for not using reverse thrust. Take a look at your operating manual 1, approach and landing tab, pg. 40. Tell me what it says about reverse thrust.
I gotta hard time buying you fly for the same airline I do and get away without using reverse thrust on the 767/757.
Why didn't you get typed in the bird like everyone else?
AAflyer
Disclaimer: I've never done a power-back, but my father's done several hundred in the DC-9 and I've talked to him quite a bit about it.jsoceanlord said:In backing away from a terminal in a 727, I heard you should roll forward a little first and then deploy the reversers--otherwise you'll blow away the terminal.
Typhoon1244 said:Disclaimer: I've never done a power-back, but my father's done several hundred in the DC-9 and I've talked to him quite a bit about it.
My understanding is that the reason for rolling forward slightly is to get the tires off the "flat spot" created by sitting stationary for a couple hours. That way it takes less time and power to get the a/c moving.
Can anybody verify that for me?
