You're better off quitting while you're ahead. You've no clue.As I previously mentioned....if you can say with a straight face to a judge that you did the right thing then you DID THE RIGHT THING! What was the warning light? Maybe it WAS justified to land on a busy street. Stupid pilots make stupid decisions and they deserve to be reprimanded for it......but most stupid pilots will admit they screwed up when the time comes.
When dealing with the FAA, you're guilty until proven innocent. You are condemned with enforcement action, and then you can appeal...but only after you've already received the penalty. Surely you know this?
If you can say with a straight face to a "judge" that you did the right thing, then...it means nothing. You don't issue yourself a violation, you don't take enforcement action against yourself. What you have to say on the matter means precious little. Surely you know this, too? No? Surely, then, you know enough to keep your mouth shut and call an attorney before you do get yourself in trouble. Weather you feel warm and fuzzy about what you did means eactly jack squat.
Stupid pilots that admit their screw up, especially to the FAA, are begging for enforcement action, and have clearly established their stupidity. Very often, the FAA has no case, except what the stupid pilot makes for the FAA. A letter of investigation is sent to the pilot, telling the pilot he has ten days to respond. The pilot, thinking anything he says will make a hill of beans difference, is stupid enough to respond. The FAA isn't interested in the pilot's explaination. The FAA isn't interersted in the pilot explaining himself so that he can get off. The FAA will use anything you say against you. There is no miranda, and no need of miranda; you're dealing with administrative law. This is regulation, coming from the Code of Federal Regulation; it is regulation and now "law."
You don't have the rights you might think you have, nor do you need to be apprised of them.
You may be familiar with the common advice that it's better to keep your mouth shut and appear a fool, than open it, and remove all doubt. Judging from your reply, I'd say not. But let's address your concerns anyway.A pilot does WHAT'S NECESSARY and everybody survives but he gets a 30 day blip on his radar from the NTSB....we'll never know if the "book" way would have had the same outcome but at least everyone is around to thank the guy/gal up front afterwards!
But first, just what on earth is a 30 day blip on radar?
Does the NTSB violate pilots? Does the NTSB have the regulatory authority to do so? Where does the violation come from, and who takes enforcement action? You need to answer this question before you make any more replies; educate yourself a little bit, because it may save your career one day.
Several years ago an instance occured in which a first officer made an error, which the captain then handled as an emergency. The captain handled the evoloution properly. The first officer had his certificates revoked for being the one who caused the emergency, whereas nothing happened to the captain, administratively. Pilots who cause, or respond to a situation inappropriately, even when they feel they're doing the right thing, are routinely violated. You do NOT have carte blance authority to deal with a situation in any way you see fit; only to deal with it appropriately to the extent necessary to handle the situation, and then no more.
If you caused the situation, heaven help you.
You apparently feel that the "thanks" of those on the ground will make up for a ruined career. But at least you get a thank you. What a stupid notion.
Plan in advance. Know your rights, know what is not your right, and for petes sake, know when to shut up. The FAA successfully violates more pilots based on their own testimony than any other source. Think about that. The pilot who admits on the radio to being off-altitude, the pilot who admits he was in an airplane at a certain time when a violation should have occured, the pilot who puts "altitude violation" in the subject header line at the top of his ASRS report, making it useable against him in enforcement action.
You do NOT know what you're talking about. Your advice may be damaging to others. Take the time to get to know this topic before you spout off.
So much to post, and too little space to post it. Continued in the next post...
