USAF and US Army C-27J Aircraft On the Way
Not in a million years.
Everything is negotiable or waiverable and comes full circle, usually more than once. If the Army starts flying its own tactical multi-engine fixed wing again, that's step 3. The C-12 was step 1 , Citations/Gulfstreams, step 2. Step by step.
Coming from the fighter community and knowing a bunch of A-10 bubba's, I'll second what Deuce said...
If I remember correctly, the A-10 thing was discussed back in the late 80's right before the airplane was going to be decommissioned. They were also working on a version of the F-16 called the A-16 with a bigger gun and some wing mods. They brought some stock (camo green) Vipers to Ft. Hood to work the ranges there with the Apaches in an effort to see how the two could work together in an Army environment.
I think the AF bitched that that type of mission was the responsibility of the AF and not the Army.
Edited: Just found this. I was not sure if my memory was that good anymore. I guess I am doing ok.
http://www.f-16.net/f-16_versions_article18.html
Also remeber they will not be deployable for at least 1-2 years once they are on property. Until the whole unit spins up ans is proficient they wont be going anywhere. Just look at the J model units. Took awhile to get that bird to the sandbox.
Kind of like the C-130J. If I remember we got the first ones in 1998/1999 time frame and they didn't deploy to OEF/OIF until 2004/2005. When I got activated in March 2003 the Brits, I-talians and Aussie were all flying them in Iraq. We embarassed ourselves with the way the "J" was integrated. Hopefully we learned our lesson and will do a better job with the C-27J.
Not a slam on the "J" guys, just a slam on the typical USAF snails pace of aircraft certification. Except the V-22, that gem is just hualing A$$ into combat. :laugh:
Don't forget about those sweet, sweet Sherpas!
I know why the Army doesn't fly A-10s, but could someone please explain why it's not part of the USMC inventory? I know it's not carrier certified, but I am pretty sure that the USMC has EA-6B and F-18 squadrons that are land based. They also have land based C-130 squadrons (obviously). Couldn't they also have a land based A-10 squadron, or do all of their tactical (non C-130) planes have to be carrier deployable even if the squadron is land based?
Jarheads, your thoughts?
You can thank AMC active duty types for THAT. They dont trust the plane and the folks they have "running" the program are old E model types that will not let go of the old outdated ways, nor will they realize the J model has capabilities the legacy aircraft don't. If the ANG and AFRES were in charge of getting the J online..it would be getting a PI on every drop (vs most) and it would have been in the desert 5 years ago.
You can thank AMC active duty types for THAT. They dont trust the plane and the folks they have "running" the program are old E model types that will not let go of the old outdated ways, nor will they realize the J model has capabilities the legacy aircraft don't. If the ANG and AFRES were in charge of getting the J online..it would be getting a PI on every drop (vs most) and it would have been in the desert 5 years ago.[/quote]
Amen, brother !!!!
Deepwater chose the CASA over the 27 on cost per unit. C27 advocates played up the commonality with the C-130J but may have overstated it and weakened their case. The first CASAs already have some significant issues (like the rest of the massive Deepwater procurement). Where the CG can piggyback on a larger deal (like the Blackhawk/Jayhawk) they usually do well. When they strike out on their own - Falcon & Dauphin they learn some expensive lessons. They usually work them out but the corporate memory in acquisition is only short term. They will likely relearn some lessons on the CASA.
MT
Is it me or does that thing strongly resemble the Aeritalia G222?
