here is answer to original ?
Have you flown and been trained in aircraft over 12500 LBS!
If you are , call number 1 703 414 9777 ext.369 this is department of justice number for Flightschoolcandidates.gov program!
Go to this website and but all your info there it is around 19 pages !
You need to have company to hire you to submit it !
There is several phases in this background check!
First you submit your info, then company who hires you goes and validates that you are candidate after that they do background check , in your case since you I assume are already flying aircraft over 12500 lbs you get to do this so called expedited way , which is faster maybe around 5-10 days!
If not it takes around 45 days from start to finish , last step is your fingerprints and after you have done that it is 2-5 days and they send you info that you are approved for training, if you have more question, pm me!
Yes and airlines are hiring, you might want to change your resume , so it is not so obvious that you are foreigner, that way you dont get discriminated because of your citizenship, yes I know it is agains the law , but so is many otherthings what happends in this country!
So but in application only info what they want and what are requirements to get the job!
forget extra languages, where you went high school etc...
