I would look for another aircraft order later this year. This will be the widebody order and quite possibly an airbus order.
It will have a similar set up as the 787 with push button overhead. Still same type. No system change.
I'd prefer to see a small guage narrowbody order. The 737 order is for 737-900s and Max 9s. If they're going to order 737s, I'd like to see some 737-600s ordered. If Airbus, then A-319s.
This order leaves a huge gap allowing for scope creep above 100 seats.
The numbers aren't that great for 737-700's unless you run them single class (i.e. SWA) the 600 is even worse which is why hardly anyone has purchased the 737-600 and no domestic carriers have.
A 737-700 and a 737-800 have very similar operating cost. One power-point slide I was shown had the operating cost of a 700 and 800 within a few hundred dollars of each other on the same 1,000 mile segment with the 700 having 30 less seats. So unless you use the specific stregnths of the 600/700 (slightly shorter fields, and slightly longer range) I don't think the short 737's work very well (relatively speaking).
