Uncomfortable shoulder straps in my Carbon Cub FX-3
Anyone else find this shoulder harness setup extremely uncomfortable? It's a single point connection that then branches off into a Y and that Y is right behind your neck meaning it's going to cut into your neck and is very uncomfortable. You would think there is a better way of doing this such as a spacer bar separating the straps behind you or something. I like many others put pads on the shoulder straps but still, it sucks.
Amazon product ASIN B07HNL79JG
I watched a YouTube video last night of a fly-in and noticed a guy in an old Cessna taildragger actually put cables on each strap and tied the cables to an overhead side tube that pulls the Y apart to alleviate this situation.
Curious of anyone else's opinion and remedy of this situation.
I went to buy another set for the rear seat and realized they have different lengths. I'm guessing I have the 10 inch on my should belts now. I'm always moving them up or down, in the past I even tried velcroing the inside to keep them in place. I see when ordering a second set they have different lengths so I'm getting the longest one this time and see how that works and hope to avoid having to adjust it all the time.
@Neal , old post but as you can tell I'm still exploring all the previous conversations and it's been incredibly valuable. Would you mind sharing what your final solution was to the uncomfortable straps?
My current solution is just a collared polo shirt. :)
Although, I have not yet found a simple solution for when I wear a life vest to cross larger water bodies…
I, of course, went with the Sheepskin. More expensive and they slide up and down and I have to use double sided carpet tape to keep them in position. I would go with Neal's choice.
Sheepskin Seat Belt Pad Cover
That looks incredibly comfortable!
