Turns after takeoff in IMC
SKYW Pilot
When's the earliest you can turn after departure in IMC. Say you're doing a 600 600 600 RVR takeoff and the DP requires a left turn to a heading. I've always heard 400 feet, but never been able to find it in the FAR's/AIM. Does the rule differ for IMC/VMC? Part 121/91? I fly for a 121 carrier and we don't have anything specified in our SOP when to turn, so I'm looking for the "Fed" answer. If anybody knows where to find it, can you post the reference? Thanks in advance!
I dont think 400 feet has anything to do with IMC or VMC. I've always been told that 400 ft. comes from the top of 2nd segment climb (which begins at gear up/doors closed and ends at 400 ft.). FAR part 25, the one that most modern transport airplanes are certified to these days requires that airplanes have to climb the best during second segment climb. Which makes sense because you would be gear up, takeoff flaps and still be at max blast. So in order to get max climb the manufacturers dictate that you reach the top of 2nd segment climb (400 ft.), before you turn.
Just my .02 cents
If you do a search on airplane takeoff profile you'll get gobs of techno-stuff on the how-to's of takeoff profiles.
There are many times the DP for an airport doesn't specify what altitude to make a turn at. If it was that easy, I wouldn't be asking the question.
Flyoa1, thanks for the response. I've heard 400' also. That number comes from the Part 25 certification? I'll try searching the internet too.
Hey check out the aero data performance section. I think In IMC you have to wait till 1,000ft unless a dp states otherwise or atc assigns a turn then it is 400ft
I don't think it is written anywhere. I've looked, and asked and never come up with anything in any regulation which would tell you that. You can, however find the basis for the 400 ft in the TERPS, in Chapter 12 which covers desiging departure procedures. They provide for Diverse departures, straight departures and turning departures. Straight departures, don't involove a significant turn (less tha 15 degrees) so aren't relevant. The Diverse departures allow a turn in any direction after takeoff, (ie: no specified Obstacle DP) and turning departures are the ones which specify: "left/right turn to heading XXX (more then 15 degrees form runway heading) "
For both the Diverse and Turning departures the Obstacle Identification Surfaces (OIS) begin with a straight segment of 2 nm, sloping to 400 ft above the departure end of the runway (DER) THe remainder of the OIS begins at 400 ft above DER, so once you're more than 400 ft above the DER, you are above the rest of the OIS. The specifications for a turning departure go as far as to specifically defne a turning departure as one which involves a climb on runway heading to 400 feet than a turn to a heading. A turn immediately after breaking ground to a heading 90 degrees from the runway heading could concievably put you below the OIS, and below obstacle protction, but that would require a pretty agressive turn.
So, we haven't answered the question really. Are you required to climb to 400 ft before turning? Well, in IMC it's a pretty good idea, regardless of the legality. Besides the question of an early low turn taking you outside of obstacle protection, there's a lot to be said for not doing anything but fly straight while you're close to the ground, reconfiguring the aircraft and transitioning from being on the with visual references to being in the air with out.
For Part 91, I would say no, there is no requirement to follow a departure procedure under Part 91, so observing the climb to 400 ft is not required. Under part 121 and 135 you are required to follow departure procedures, so presumably, you would be required to climb to 400 ft before turning. That is the way departures are designed, however, it's almost impossible to know that without reading the TERPS.
One thing to consider, some departures are worded in a way that suggests the turn needs to happen pretty quickly. It's not uncommon to see "left turn as soon as soon as practical" and I know a couple of places where its: "immediate left turn" I would say that in these cases, it's ok to start the turn as soon as you can.
Does all this translate to a requirement to not turn before 400 ft in good visual conditions? That's less clear. Let's just put it this way, On a 121 flight with a fed on the jumpseat, I would be careful to make no turns below 400 ft in any conditions. If you do, you know you're on solid ground.
Thanks, A Squared! That's exactly what I was looking for!
Hey, GOTAFLY,
The Aerodata we use at Skywest says our obstacle clearance is based off no turns below 1000 feet unless....
1) ATC instruction
2) DP
3) SDP (Special Engine Failure Procedure (Skywest thing))
The question is raised (and has been discussed in length previously), when to start the turn when you have a DP to fly. e.g. ACV- The Hocut3 departure says to intercept the 250 off ACV to HOCUT. In IMC, I start that turn at 400' since the TERPS assume that. Some pilots think you should wait til 1000 feet and turn since the DP doesn't state "Turn as soon as practical/possible." It's kind of a gray area. Obviously, as PIC it's up to you to figure which is best.
Skyw pilot, I agree with you, it is a gray area. I turn at 400ft also. I think the correct way according to aerodata would be as stated above. No other airline I have flown with (5) including skywest waited till reaching 1,000 IMC OR VMC.
Being a retired terps guy, A squared is correct, 400' is the standard first opportunity to turn IMC, you can also turn immediately after T/O IF ATC advises you to, such as T/O from LAX 24L, they sometimes want you to turn left to 230 deg right after liftoff, it is legal as they are then buying responsibility for your terrain clearance.
Your mileage may vary based on company FOM.
The only place we have it is in our standard profiles - which is to say our standard takeoff profile has any departure turn commenced at 400 feet.
I believe, as others have posted, that's based in airplane certification and TERPs requirements.
It has nothing to do with airplane certification...the 400-ft initial turn applies to Part 23, CAR3, and Aeronautical Bulletin 7a aircraft as well...and as far as I've found, none of these aircraft have any mention of 400 feet in their certification requirements.
As an aside, I heard a rumor that the 400-ft minimum for second segment came about because that was where the DC-3 engine had to be reduced to METO power in order to prevent overheating in single-engine takeoff procedures. Highly entertaining, if it's true ;)
Fly safe!
David
minitour said:
runway heading to 400' then 200' per nm is standard...ill try to find the reference later.
-mini
AIM 5-2-6.b.1.
midlifeflyer said:
AIM 5-2-6.b.1.
Thanks, I'm relieved that the TERPs isn't the only official source for important operational information like that, but a little embarrased I didn't know where to find it.
