MJEPilot,
A free spinning turbine is one that has no direct linkage to the rest of the engine core. High pressure gases moving through the turbine section flow into a separate area, commonly called the power section, and turn an additional turbine which is linked to the propeller with its own independent shaft. This is different from a direct drive engine, in which the propeller is connected directly to the compressor shaft through a series of reduction gears.
The reverse command that I believe you're referring to is the "region of reverse command", or more commonly being "behind the power curve". Basically this occurs at a particular point, usually on final approach when the aircraft is configured for landing, when the amount of drag being produced overcomes the lift when the aircraft is flown at too slow an airspeed. Essentially lift is just a component of angle of attack times velocity. When you get "low and slow" on final with gear and flaps extended you must add more and more power in order to maintain a specific glidepath or altitude. There comes a point when the total drag will exceed the power available to maintain this altitude. This is called being on the backside of the power curve or in the region of reverse command. The only way to increase the lift is to reduce pitch and allow the airspeed to build and "nurse it" back, so to speak. Retracting the gear, if applicable, might help the situation, but a sudden flap retraction will decrease lift and make a bad situation worse. As you can see, this is not a desirable situation to be in. It has been awhile since I've thought about this stuff in any great detail, so maybe somebody else can chime in and expand a bit.
Hope this helps...
KingAirKiddo
