punkpilot48 said:That one you are talking about diverted to springfield. I dont remember if that is SPI or SDF. They say that having the dv windows open was letting in moisture and getting the cockpit electronics fried. The crew did an amazing job on that one if you read the report.
thowe21 said:I find it hard to believe that opening the dv's is causing fire in the cockpit. Window seals are not made to last forever wether they are being opened or not!
punkpilot48 said:I know it was just a joke....
thowe21 said:I am positive that the first one landed at sdf which is louisville. I have heard nothing of one going into IND, and heard nothing of one going into ABE either. Intresting, Im sure that if it is true we'll find out soon. If it is true and two had smoke in the cockpit due to the same thing then I would think that the feds would step in and find out if it is a design flaw or shauddy MX. I find it hard to believe that opening the dv's is causing fire in the cockpit. Window seals are not made to last forever wether they are being opened or not!
mckpickle said:We have heard of a smoke problem caused by faulty windshield heat controllers. ...I had heard that was the cause of the TSA SGF incident.
Shrek said:Those airplanes are old as sin...... 801-808HK or so.
mckpickle said:As if you guys don't have enough to deal with.
johndt said:I haven't heard anything about a fire @ IND. Anybody else heard anything?
BoilerUP said:I was in the terminal at IND when it happened. I looked up and saw a blue chicken tail airplane with a ton of CFR surrounding it. I spoke to some of the pax who got off the Tiger parking bus used to bring them to the AA gates and one said "The airplane was on fire. There was smoke in the cabin." These were his words, not mine. When I finally got out of IND, I saw this airplane on the hardstand where they park overnight airplanes.
Not trying to post any flamebait or spread anything here, just curious what happened...
great cornholio said:You sure it was TSA and not CHQ??? Anyways if it was TSA then thats like our 4th or 5th fire so far in 2006. I think I might invest in one of those silver airport firefighter uniforms before my next trip...
Reebo said:Trans States has only had one "fire" in it's history. Many "smoke" events, but only one actual "fire".
great cornholio said:Good point...but its still happening way too often all of a sudden.
