hydroflyer
- Feb 16, 2003
I'm not sure about the other models, but with the 310R if you try landing with full flaps and are near the forward CG limit, the plane will have a hard time flaring and will land in more of a 3-point attitude. It is much easier to land the plane with 20 degrees of flaps or less with a far forward CG to get some sort of flare.
People always have litttle tricks for starting the engines, but usually the POH procedures work just fine. Be familiar with those listed especially for the hot starts.
If it is really warm outside and you have to hold short or idle for an extended period of time, watch your engine temps as they can creep near redline and then exceed it on takeoff.
Try not to land with any side drift in a crosswind with the gear. Differential thrust works well when landing in a crosswind if necessary.
Most of my time in the 310 was spent hand-flying it and I felt it was a great plane for that as it trimmed out well and could fly hands off nicely. Original "Nav-o-matic" autopilots could be suspect.
AOPA's Safety Foundation has a book on the 310 that includes highlights of accidents and typical problem spots with the plane. The book would be a good addition to a school that uses the plane for training.
