I have an interview and a flight test that will be done in the Caravan. I have never been in one nor have any turbine time. Any power settings speeds, and suggestions would be appreciated!!
Easy to fly.
Ice. Just act like it has no de-icing systems and make every effort to leave
the icing conditions IMMEDIATELY. 120KIAS is the magic number. If you can't
maintain that, it's time to find an airport or find warm air.
Enjoy it. It's a great plane.
CE
Hmm, I dont have any straight and level time in the Caravan, I flew skydivers in it. She's a great bird, very docile and responsive. All I know is power to flight idle at 13,500' and pitch 5 knots below Vmo and your main wheels will be on the ground in 2 minutes and 50 seconds. When you set the power for takeoff, add it slowly, and make sure you set it about 50 lbs or more below red line torque (1870 ft/lbs I THINK) because it will ram rise as your airspeed increases. You will need to keep advancing the power lever to mantain a certain torque setting in the climb, it decreases with altitude similar to manifold pressure. Also, she's pretty nose heavy in the flare, so dont take the power out early and be ready for a good bit of back pressure to get her nose up. Enjoy and good luck bro!
A very important thing to remember about the Van, in addition to the points brought up already in this thread, is the way the wing is constructed. Take a look at the diagram of the plane and you'll notice two things. One: the airlerons are pathetically small for a wing that big. Two: the flaps are enormous, darn near the size of a 172 wing. Keep these points in mind as you're flying the thing.
With those tiny ailerons, your roll responsiveness is going to be lousy at best. That means your ability to correct course and heading will be adversely affected and locking onto a localizer can be an exercise in hilarity and frustration if you're not careful. Best bet is to keep the corrections tight, and focus on locking onto a heading rather than chasing the localizer needle.
With the gigantic flaps, the airplane WILL react when you move them. Take out flaps, and the plane will literally fall out from under you. Extend flaps, and the thing will feel like it's leaping towards the moon. Anticipate these reactions when you move the flaps and be ready on the elevator. Depending on the speed, you're going to have to push/pull suprisingly hard on that control wheel to maintain an altitude or a glideslope.
Oh, one more thing. Keep that ball centered at all times. If you should happen to stall the sucker and it's not coordinated, you're going for a ride that you will NOT enjoy.
Is there a story behind that remark![]()
You know how to fly a 172??? Then you can fly a caravan
You wise BASS, how you doing Bro?
I think ive heard that story...
Regarding the posting from Prince deitrick (sorry if I spelled it wrong) I am sure he has a story behind that statement. However, remember there are also spoilers on top of the wing assisting the lateral movement of the aircraft. lets face it, look at the bird, she is big and bulky, but she handles absolutely fine. You will find her harder to turn on the high end of the airspeed indicator. but you shouldnt be nose diving it into the runway at red line while turning anyway.
Thanks for all the input, I was offered the job right after the flight!The van flys just like a C-182 very simple. I was going to try and hold out for an FO position in the corporate world but being unemployed and needing a job is another thing.Plus it seems like a great place to work the CP and owner were very nice and made sure that they stressed safety during the interview which I liked. The run is very very short so I won't build a lot of turbine time. I am not sure how well single turbine time will help me later down the road but I think its going to a good place to work!
There is indeed, and it is an integral part of the reason why I'm a retired freight dawg now. For a case of beer I'll share it.
One more pearl of wisdom to BGSM. I'm not sure how in depth they're going to get in this flight check you're going to take, but keep a keen eye on that annunciator panel. If you see, or if the person administering the flight check mentions that you see, either the "Reservoir Fuel Low" light or the "Chip Detector" light there is only one acceptable course of action for either one. Drop whatever you are doing at that particular moment, declare an emergency, and get your butt to an airport NOW! There are good reasons why those particular indicators are refered to as the "OH S$%@!" lights.
You should probably pay attention to the warning horns before you get the res. low light.
I'm a mechanic with 13 years on Caravan only experience most with a Fedex feeder operation and have never heard of a chip light illuminating (outside of testing them on phases). PT6's are not metal makers like Garrett 331's.
