Tinmouse 737 flight sim question
Wedge
Member
Found a great 737-200 add on for MS Flight Sim 2004, but I can't seem to get the nav radios to tune for approaches. The comm radios work fine, but the numbers on the nav radios won't change using either the +/- arrows or the N key function. Anyone have any advice for this, or is this just a problem with my download?
http://tinmouse.org/
Thanks. That 737NG sim looks pretty hot. Mainly I'm trying to find a working -200 sim since I'm going for the type soon and want to acquaint myself with the picture in that cockpit (six pack instead of EFIS, older autopilot, FD, etc). Any advice is appreciated.
Insert this into the aircraft.cfg under the radio section:
// Radio Type=available, standby frequency, has glide slope
Audio.1=1
Com.1=1, 0
Com.2=1, 0
Nav.1=1, 0, 1
Nav.2=1, 0, 0
Adf.1=1
Transponder.1=1
Marker.1=1
That should hopefully make it work, as I had the same problem and this solved it.
I had just about given up on getting the sim to work, but your code change fixed the problem. Thanks Pugh!
