Mmmmmm Burritos said:All that matters is..... did they deploy the TR's or not?
Why don't other carriers use em? Is there still a problem with uncommanded deployment?
chperplt said:If your question is based on that quote, you missed the point of the quote.
CLECA said:No, it just reminded me that no one else really uses them and couldn't remember why. We use them on every landing and I knew others don't. Someone, I think it was CHQ, that has a few A/C without them even installed.
CLECA said:Why don't other carriers use em? Is there still a problem with uncommanded deployment?
BlackPilot628 said:We had one at CHQ on the United Express side. That airplane has been added to the Charter department. Trans-states has a crap load of E145 with no TR's. It doesn't really make sense to me either. Last time I sat in the Jumpseat of a TSA plane the capt. was explaining to me that they take a weight penalty on planes without TR's.
BlackPilot628 said:Last time I sat in the Jumpseat of a TSA plane the capt. was explaining to me that they take a weight penalty on planes without TR's.
michael707767 said:actually, thats BS. Aircraft are certified for take off and landing distances without TRs, so there would be no penalty.
blzr said:You think? I bet it adds a lot to your accelerate/stop dist.
91 said:With all due respect, I believe that those figures are calculated without the use of reverse. After all, what is one of the biggest reasons you'd need to stop before V1, engine failure right? So you bag an engine and need to stop, well you've only got one reverser now anyway, AND it's probably going to be giving you some assymetrical reverse that could pose a problem if you need alot of it.
But I could be wrong. Comments or additions?
BigShotXJTdrvr said:In my opinion, TRs are a useful EXTRA tool, but sometimes I have to remind FOs that we actually do have brakes, and we are allowed to use them at wheel spinup +3 seconds (FAR, FAR quicker to stop a plane than waiting for the engines to spool). Most FOs at XJET have been conditioned for excessive use/dependence on reversers. It's bad airmanship and I'm getting freakin' tired of having to fix problems that check airmen should be fixing. And no I don't want to be a check airman, not any more than I already am, anyway.
purduedchi said:TR's can be used in the calculations of take-off performance. They are never used for calculations when it comes to landings. I have found this out due to numerous amounts of research at my company. On our 145's with thrust reversers, you may defer 1, and only one thrust reverser at a time. Most who fly the airplane understand Qty inst...2, num req 1. However, we also have a s#%tload of european ones that have no thrust reversers. How is it that we can fly some of the same airplanes with no thrust reverser, but other we must have one operational. I was told that you have to account for the worst case scenario. Basically, the reason you can defer one and only one if it is installed is because if you have an egine failure before V1(accelerate stop), you will have the the operating engine AND it's reverser available too you. They did give us some guidance as far as part 25 certification, but I can't find it right now, if I do, I'll post it for you
michael707767 said:I have never heard of an airplane being certified with TRs. As 91,100 said, if you need to stop during takeoff, its likely to be because of an engine failure. I have never flown an aircraft that was certified with TRs, have asked the question everytime.
pianoman said:According to our latest revision, XJT recommends deploying the reversers, but only spooling them up if necessary for safety reasons. They want you to use the brakes instead, since heating them up wears the carbon brakes less.
Apparently when they warm up this film forms that reduces wear. I know, sounds weird but that's what Embraer says.
Interesting. Completely the opposite at Eagle. Our ops are fairly strict about when we can use reverse. Runway less than 7000', or wet runway of any length, and then only at idle.BigShotXJTdrvr said:Most FOs at XJET have been conditioned for excessive use/dependence on reversers.
