You weren't. You described what dutch roll tendency is. I'm not sure how the very different coordination exercise got the same name.firstthird said:Didn't mean to be too much of a smart aleck with my earlier response
bobbysamd said:Are we sure they aren't a kind of bread that is eaten in Delft?
Dutch Roll - bill howell
Many swept wing aircraft suffer a dynamic instability problem known as Dutch Roll.
Dutch roll happens when the aircraft has relatively strong static lateral stability (usually due to the swept wings) and somewhat weak directional stability (relatively.) In a Dutch roll the aircraft begins to yaw due to a gust or other input. The yaw is slow damping out so the aircraft begins to roll before the yaw is stopped (due to the increased speed of the advancing wing and the increased lift due to the swept wing effect.)
By the time the yaw stops and begins to swing back toward zero slip the aircraft has developed a considerable roll rate and due to momentum plus the slip angle the aircraft continues to roll even once the nose has begun returning to the original slip angle.
Eventually the yaw overshoots the zero slip angle causing the wings to begin rolling back in the opposite direction.
The whole procedure repeats, sometimes with large motions, sometimes witch just a small churning motion. Like all dynamic stability problems, Dutch roll is much worse at high altitudes where the air is less dense.
Dutch roll is almost certain to happen in a jet aircraft if the Yaw dampener is turned off at high altitude. Therefore, the first thing to check if an aircraft begins to exhibit Dutch roll is that the Yaw Dampener is on. The pilot should then try to minimize the yawing oscillations by blocking the rudder pedals (i.e. hold the rudder pedals in the neutral position.) Next apply aileron (spoiler) control opposite to the roll. The best technique to use is short jabs of ailerons applied opposite to the roll. Try to give one quick jab on each cycle (i.e. turn the wheel toward the rising wing, then return it to neutral.) Finally accelerate to a higher speed, where directional stability will be better, or descend into more dense air, for the same reason.
Here's another example of terminology being used in error. I’d never thought this would need any discussion, however several computer forum exchanges within the past few months have delved into this subject and – in the words of one student of my acquaintance – “Wow, those guys must really be misinformed, huh?”
Before we get into a discussion of the “rolls” we’re talking about here, I should mention a couple “tongue-in-cheek” definitions of “rolls” and aerobatics from the CAF dictionary of the past (circa 1967); they just somehow seemed apropos to this subject. The “sweet roll” (as well as the “Puerto Rican sixteen”) found their way into that dictionary as maneuvers.
Anyhow, now back to the serious stuff. Over the years, I’ve seen this [the following] maneuver taught in two or three ways. And I’ve taught different ways of doing it – depending upon the objective. So I guess we have a consensus among flight instructors of the maneuver’s validity – but not of the terminology.
(1) One method would be while in straight and level flight to pick a point on the horizon and enter a turn away from it for some amount of turn and then, without stopping, reverse the turn to pass through the original point in the opposite direction, then again reverse the turn and so on, while all the time coordinating the flight controls (especially the rudder and ailerons). (2) Another variation or method used is to pick a straight road or a point on the horizon. Then precisely hold that point while initiating a bank (takes opposite rudder), then reverse the bank to an equal amount in the opposite direction. This is repeated over and over while using the flight controls to precisely maintain that point (especially the rudder and ailerons). This variation especially lends itself to getting the student ready for the aggressive use of the rudder in acrobatic flight.
Evidently – to a certain number of instructors – the above aileron/rudder coordination exercises (especially #2, the one that holds the reference point) that we all give our new students are called “dutch rolls”.
Well, we’ve got some news for you, chum! Those aren’t “dutch rolls”, they’re simply plain old garden variety “coordination exercises” or “coordination rolls”. And – undeniably – they’re extremely useful for teaching coordination or for quickly evaluating an aircraft’s handling qualities! I’ve used them from the very first time I took my first lesson in an Aeronca Champ right up until the present. When we were aviation cadets in “Bevo” Howard’s USAF T-6 school, we were taught them from the very first day of our flight training. BUT THOSE ARE NOT DUTCH ROLLS! You copy that? “Sorry Charlie” but no cigar, those are NOT dutch rolls! No big deal, you say? Well, OK, but you need to realize that when you use an incorrect term it’s teaching your student something completely wrong. It’s sort of like the media using the term “Piper Cub” for every airplane less than a medium sized jet. And – besides perpetrating a falsehood – it can later kill him/her! And if you don’t think or realize that a dutch roll can easily become lethal, look up the Braniff/Boeing 707 (N-7071) flight training accident involving the tossing of a couple of pylon mounted engines off the wings in the fall of 1959.
Dutch roll is a motion exhibiting characteristics of both directional divergence and spiral divergence. The lateral stability is strong, whereas the directional stability is weak. If a sideslip disturbance occurs, as the airplane yaws in one direction, the airplane rolls away in a countermotion. The airplane wags its tail from side to side.
Ventral fins, although primarily used to augment the vertical fin that may be in the wake of the wing at high angles of attack, are also beneficial in decreasing the lateral stability and increasing the directional stability to reduce the effects of Dutch roll.
You may be on to something....avbug said:The name is a racial slur, in the same way we speak of a polish fire drill. It's a dutch roll.
My list of English expressions featuring the Dutch. I collected this list from various dictionaries. Does the fact that most of these expressions are unfavourable say something about the English or about the Dutch?
In the Dutch language this is known as 'schoonrijden' which translates into graceful but controlled skating. It is beautiful and serene in its appearance. The purpose of the rolling is to place curved strokes on the ice by skating in turn on the outer edge of the runner blades only in a regular pace
I suppose that just as much of our aviation language originated from naval terms, the origin of the Dutch-roll could have come from the peculiar sideways shift of the stern of an apple-bowed caravel (Dutchman) when running before a following sea. As the stern was lifted by the oncoming wave it would swing to one side, the hull would roll as the swell passed, and the stern would swing back onto the course-line as the breaker moved under the bow and the hull rolled upright.
In an aircraft, especially those with V-tails, it is a tendency for the tail to wander off the line-of-flight far enough to generate a straightening force, but overshooting the correction only to repeat the excursion on the other side. If accompanied with a pitch variant, the tail may oscillate in a circle. The Dutch-roll in ship and aircraft is an undesirable characteristic.
