coolyokeluke
- Nov 21, 2002
I.P. Freley said:The problem I see with the above is that modern auto engines are far more powerful than their more ancient brethren in cars, to the extent that a 3-liter auto engine in something as mundane as a Honda or Mazda sedan makes as much power as an engine of twice the displacement from thirty years ago, with lower-octane fuel and no commensurate bump in compression ratio. Of course they achieve it at a higher RPM... But not something as crazy as TWICE the RPM.
Obviously I've forgotten a lot about the basics of engines, at least as far as the math is concerned.
Those smaller engines with higher operating RPM's would require reduction gears if affixed to a propeller. They don't make much torque at low RPM like the older, larger displacement car and airplane engines. So not having a gearbox is a weight saving issue as well as something else that could break in an airplane. I'm speculating here, but I think the idea of air/vs liquid cooling comes down to the same issues; weight and complexity. As far as sticking a 350 V8 on an airplane, lots of homebuilders have done it. One of the issues I always hear about with car engines in aircraft is that our large displacement low horsepower aircraft engines are designed to run flat-out, where car engines rarely and only briefly make maximum power. I'm all for advancing the state of aircraft engine technology, but there are reasons (one of which has sadly been liablity issues) that our engines have changed little in the last 50 years: relaiblity and weight.
