Lead Sled
Sitt'n on the throne...
- Apr 1, 2004
And $20 million would be better than $15 million and $25 million...Yes, I have seen them over there. It sounds like it is a bit marginal as well, especially if you need to fill it up with people. Plus I think that you have to take a number to get one.
15 million is a better number. You might be able to find an older 604 or a 900 in that range.
Come on guys, if your budget is $10 million then that's the budget. If runway performance is an issue (as it was in our case) then a DA-50 is probably the most workable solution for $10 million. If runway performance isn't an issue then an older challenger may work. Everything else mentioned have issues that make them unworkable in the long-run.
LS
