~~~^~~~ said:
Why does ALPA encourage airline management to operate alter ego air carriers? Why do we allow our union to negotiate these deals?
This E170 "revolution" is being done with Duane Woerth's signature at the bottom of every contract.
We truly are our own worst enemy.
Now I have read this about 5 times and I just can not figure out how you got about making this kind of false & misleading statement. While I would endorse ALPA (or ALPO) as a whole, I can not endorse each indiviudal pilot group and their respective decisions.
GoJet is simply a method of side-stepping the TSA ALPA pilot group. I don't think you can look any other way at it. It's not ALPA or the APA that has chosen this outcome...it's TSA MGMT/HK.
Case in point...Freedom Airlines. I'll give you a little background for explaination.
Mesa MGMT began by using the U scope language as the reason for operating aircraft in the set range (yes, sim to APA scope). A real fix was put forth by the Mesa MEC (ALPA Group) to have the AAA MEC (U) change their scope....hence, completed.
With the scope relief, Mesa could now operate the CRJ 700/900s under the Mesa certificate with the Mesa pilots. Heck, they could have used the Mesa pilots at Freedom, but MGMT continued to head down the path of desruction of spending millions of dollars to create a new airline.
In the end, where is Mesa? All CRJ 700/900 aircraft are at Mesa Airlines proper. Where is Freeedom, well...1 Beech 1900 to keep the certificate. So, why the millions of dollars on Freedom? Why the countless hours of the FAAs time and taxpayers dollars? Why the alter-ego? Just for 1 Beech?
So - as you can see, not ALPAs fault....next slide please!
Also, even if TSA needs to create a new certificate, they can use their EXISTING pilots to fly the airplanes. Now the TSA pilots just have to bargain for those jobs.
I would put money on it saying that both groups should be integrated in the future.
