GEUAviator
Active member
- Oct 4, 2002
When planning a climbout to altitude for cross countrys the student and myself will typically use the "Time, Fuel, & Distance to Climb" chart located in the POH.
Now, every chart I've come across only says to increase time, fuel, and distance by ~10% for every 10 degrees above standard. No big whoop...
But, these charts never say anything about effects of wind. The "Time, Fuel, & Distance" charts give data based on no wind.
What's the best way to make more accurate calculations? How would you explain this to a student pilot?
I'm aware of using Pythagoras' Theorem and using vector analysis to find the correct distance and groundspeed , but I'd like to find a better way of coming up with more accurate numbers.
Example: Climb from 1,000 ft. to 6,000 ft. we're climbing at 70 KIAS. Normally I'd just get add/subtract winds to get a groundspeed. How should I do this for the climbout?
Thanks in advance for any responses! I'm just trying to be the best CFI I can be!
GEUAviator
GEUAviator
