siouxicide
Gimme yo' change
- Sep 19, 2003
Recommended reading for all that don't understand TAS:
True airspeed defined Check out the second sentence.
Hey...
Someone please teach me why I listen to Turboprop drivers always discussing airspeed.
Ummmm in real life if you cant understand the relationship between something as simple as tas and gs you really should rethink all that theoretical bull you learnt again...it might come in handy one day!
I think I'm going to have to take issue with that. I don't have much time in King Airs, but the Metros and Jet Streams that I flew had tons to gain by climbing.
First, I can rarely reach 100% torque on any given day. So, flying at 100% power just isn't an option.
Now I have been around all sorts of airplanes forever. Worked on just about everything including being a jet and turboprop engine overhaul guy and inspector
Lets see so far had 6 engine failures, a cockpit fire, loss of 3 gens 4 nose gear malfunctions, loss of two hydraulics sytems
As a pilot I care about is my speed across the ground depending on the altitude in still air....
The only thing that matters is the one on the dial or tape....
I'm going to second that the best altitude isn't always the highest you can get to.
The Metro I fly gets the best TAS at FL190 and FL200. I also get a huge fuel drop from 17,000 to FL190 but virtually no drop above FL200. I can go to FL300 (if I had RVSM) but I lose about 30 kTAS.
So, when you hear KA pilots talking airspeed (guessing its TAS) at certain altitudes, they are just comparing their best performance.
Last I checked, the book says the best TAS for a metro is in the 10-15k range depending on temperature and weight. Best TAS comes at the highest altitude that you can hold the barber pole.
With winds calm, I get about 260K TAS from 12k - ~22k at 100%rpm and max torque, obviously i head up to 220 for the increased fuel savings. Also, I don't agree with the guy who said he sees little fuel savings above 190, I drop an extra 75-125lbs/hr going from 190 to around 230 with no ground speed reduction
edit: it probably depends on how long your legs are if climbing above 190 is worth it as the metro tends to bog down around there. I'm frequently on 4-5hr legs so it's worth it for me.
Okay, as an "outsider" to this thread, it strikes me as mentionable that the original post is headlined: "teach me..."
Then, when people try to do just that, the original poster becomes defensive and starts talking about the number of engine failures, etc., that he has experienced. My observation/suggestion is this: It's better to say TAS than "airspeed across the ground depending on altitude in still air". ("Depending on altitude" impliedly taking temperature into account.) And if the more laborious description is used, then openness to its general equivalence to TAS should be entertained. Don't say "teach me" if you are not open to such input. The poster who said he had teaching/instructional experience acted reasonably in responding to a "teach me" post.
Hmmm - are you a pilot?
