I have a taxi light on/off switch on my panel on the lower left of the G3X area with a 5A fuse. As the wing leading edge lights point up while taxiing the light for taxiing at night will be minimal. I've done it, it's doable but I wanted better so I installed a taxi light. On my prior FX-3 I used a 10 inch RIGID light which worked fine but when at EAA AirVenture 2023 I looked at the Whelen lights and noticed the dedicated taxi light as used in many nosewheel aircraft. The specs looked good and the gears starting turning in what I wanted to use in my new FX-3.
Not a cheap setup but I decided to pursue the Whelen option over the RIGID light bar.
Whelen Parmetheus™ G3 PAR 36 Landing & Taxi Light FAA-PMA | Aircraft Spruce (be sure to choose the taxi light option, not landing light)
www.aircraftspruce.com
Now the question is, as always, how to mount it. As I enjoy CAD design and 3D printing I designed a mount that attaches to my cabane vee. Works outstanding and the light can be retracted when not needed (manually! I'm not Patey!). I probably won't retract it, I don't think the drag is a big deal or a concern to me, if much at all.
After deciding on my design and several 3D print tests I used a CNC service (Xometry) to send my design off to be CNC'd out of aluminum and double black anodized. As it didn't cost much more to get 10 vs. 1 made I got 10 made which cost about $1k. So I have 9 extras if anyone wants one.
The end result came out amazing, the light works amazing and I love the setup. Initially I didn't paint it black and left it white but after the bullying by several friends I caved and painted it black
I have to say they were right, but don't tell them!
Whelen A715-1 Landing Light Housing Only | Aircraft Spruce ®
Whelen A715-1 Landing Light Housing Only The Model A715-1 landing light is standard equipment on new Beechcraft, and will retrofit into older aircraft, as well.
