TAT or SAT
av8tor02
I was just putting a book together and figured I would go with the best experience for this question. Anyone know what a great definition of TAT or SAT would be. Thanks in advance.
TAT = Total Air Temperature. This is the temperature of the air measured approximately by a temperature probe. It is higher than the static air temperature due to ram pressure, or Mach heating caused by the motion of the aircraft through the air.
SAT = Static Air Temperature. This is the temperature of the air surrounding the aircraft.
Indicated SAT and TAT shouldn't be used on the ground, or at least if you want accurate informtion.
ASH said:
SAT is used on the ground
TAT is used in the air and is a derived temp.;)
Actually TAT is a measured temp and SAT is a derived temp...
TAT is higher due to frictional heating.
SAT - Static Air Temperature and is the temp of still air.
*Sidenote*
I always thought that to determine the possibility of icing in precip, you used SAT rather than TAT. Is that correct?
Actually, SAT is what we do when drink beer with a bro...
...we SAT on the porch, boozed it up, and waxed about the old times..
TAT is 1/2 of what a nice looking bimbo has a great pair of.
I know these things as I am the consumate aviation professional (not..)
I disagree with my good friend H25B.
On just about every aircraft that i've flown the manufacturer suggested that TAT be used in order to decide when to turn on the ice protection.
Why? Think of it in simple terms, TAT is the temperature that the skin of the airplane THINKS it is.
So if it is zero degrees C' and you accelerate to 290, ram-air, friction, etc. might yield a TAT of +11'C thereby eliminating the need for ice protection.
Now on those same aircraft SAT is used to determine when you may turn off the antiice when the temperature is so cold that any moisture it carries will be in the form of ice crystals (usually -40'C SAT or colder).
It's best to use SAT and TAT, don't forget RAT
dhampton said:
What he said.... except at SWA we use plus 10 TAT
The DC9/MD80 uses RAT mostly.
I agree with FurloughedAgain.
So when ATC wants to know your temp, what do you guys give them?
FMS Progress page 2....
I usally read what is on the progress page, along with the winds or SAT from the panel.
ATC is looking for SAT if they ask. I think they could care less what your measured TAT is.
SAT= past tense of SIT
TAT= usually slang for "tattoo"
Hope I have been of some help.
Regards,
XTW
labbats said:
*Sidenote*
Typically TAT is used to determine if you need to have the anti-ice on or not... In the Falcon 900EX if we are in at a TAT of +10°C or less in visible moisture we turn on the anti-ice...
I guess I've always been thinking of it in terms of, "How cold is it outside ???" In which case SAT is the most accurate answer to that simple question. I'll have to look at the Lear manual and see what they recommend using for anti-ice purposes. Sort of splitting hairs but nonetheless interesting...
I've been enlightened...
Not interesting at all.
Look at the gage in your cockpit. Whatever it reads, reference your CFM (AFM) ... do what it tells you to do. For an in-depth discussion on Bernoulli equations and temperature gradients, there are several great textbooks I remember from college that spell that cr@p out.
As an aero engineer, I say fly what the book tells you to fly....
And the answer is
SAT - Static Air Temperature. Also called OAT. This is the temperature of the air surrounding the aircraft.
TAT - Total Air Temperature. This is the temperature of the air measured approximately by a temperature probe (such as a Rosemount). It is higher than the static air temperature due to ram pressure, or Mach, heating caused by the motion of the aircraft through the air. I say "approximately" because there are many factors that make the measured temperature slightly different from the true total air temperature.
http://mtp.jpl.nasa.gov/notes/software/Nomenclature%20and%20Abbreviations.html
The simple answer is that static air temperature is the outside temperature and total air temperature is the air temperature adjusted for the ram pressure heating caused by the motion of the aircraft.
Splitting hairs??? :confused:
In the Lear 35 with a SAT of -56°C (ISA) doing Mach 0.78 your TAT would be about -30°C, that is a 24°C difference (43.2°F difference) TAT vs. SAT...
I would hardly call that "Splitting Hairs"... :eek:
O.K., the splitting hairs remark was a poor choice of words to say the least along with the guy that said this discussion wasn't interesting...
Now excuse my ignorance and educate me please. When defining "icing conditions" in terms of temps. at which ice accumulation occurs do the manufacturers (i.e. Learjet, Dassault, Raytheon, etc...) vary on which temp. to use ???
Now, if the true ambient temp. (i.e. SAT) is not conducive to ice accretion but the TAT is .... THEN WHAT ?? I guess my question comes from the point that I have evidently ignorantly been going by SAT and have never been surpised by ice forming unexpectantly.
If the SAT is so cold that icing is virtually impossible is it then possible for the ram-air heating effect to somehow create an a condition where icing is possible... ???...
Actually, you use both SAT and TAT for ice protection purposes.
On the EMB-145, we will use SAT temperature with visible moisture for determining whether or not to use engine anti-ice for takeoff. 10 degrees C SAT is the limit. However in flight, we use TAT to determine the need for ice. Actually, since our system is automatic, the airplane determines for itself when it needs ice protection. However, for our ice protection system checks, we must be below 10 degrees C TAT.
So the above posts are right; TAT is used in flight to determine the need for anti-ice. However, SAT is also used, but on the ground.
I see this all the time! Too many pilots who have no idea how to read a TAT/SAT gauge.
TAT is what the airplane feels it is outside. So you better turn all your anti-ice equipment if its below +10TAT. Some manufacturers have limits on the minimum temperature to put anti-ice on. I've seen -27TAT, -40SAT etc. Regardless, the vast majority of icing will occur between -10TAT and +10TAT in visible moisture.
Example: You are doing 250KIAS at 10,000. Your TAT gauge reads +8 and SAT is -12. Better put that anti-ice on. Your smart Captain brings the throttles up and accelerates to 330IAS. Guess what? SAT is still -12, but TAT increased to +13. Turn off the anti-ice, you don't need it anymore. Know the relationship between IAS and TAT and you'll be a much safer pilot.
Happy flying.
I think the confusion arises because some aircraft (specifically the light lears) specify SAT.
I don't understand why either, but perhaps there's an engineer type out there who can explain it to us.
This is the first airplane i've flown where TAT is ignored -- sometimes much to our detriment while trying to climb with the anticlimb selected "on". ;)
I'd kinda be thinkin....What if I was like a itty bitty like molecule of like air, and like I'm just chillin' and mindin my business, y'know, and like hangin with dem other oxygen and nitrogen dudes, and all da sudden,
WHAM!!!!!!! Smacked by like dis big wing and stufff! OUCH!!!!
Yeah, I guess I'd be gettin heated up about dat, so is dat kinda why like TAT is like hotter dan SAT????????
Freakin wierd, Dude, yeah, wierd.
