BID said:I agree with FurloughedAgain.
So when ATC wants to know your temp, what do you guys give them?
Typically TAT is used to determine if you need to have the anti-ice on or not... In the Falcon 900EX if we are in at a TAT of +10°C or less in visible moisture we turn on the anti-ice...labbats said:*Sidenote*
I always thought that to determine the possibility of icing in precip, you used SAT rather than TAT. Is that correct?
FurloughedAgain said:I disagree with my good friend H25B.
On just about every aircraft that i've flown the manufacturer suggested that TAT be used in order to decide when to turn on the ice protection.
Why? Think of it in simple terms, TAT is the temperature that the skin of the airplane THINKS it is.
So if it is zero degrees C' and you accelerate to 290, ram-air, friction, etc. might yield a TAT of +11'C thereby eliminating the need for ice protection.
Now on those same aircraft SAT is used to determine when you may turn off the antiice when the temperature is so cold that any moisture it carries will be in the form of ice crystals (usually -40'C SAT or colder).
h25b said:I guess I've always been thinking of it in terms of, "How cold is it outside ???" In which case SAT is the most accurate answer to that simple question. I'll have to look at the Lear manual and see what they recommend using for anti-ice purposes. Sort of splitting hairs but nonetheless interesting...
I've been enlightened...
Splitting hairs???h25b said:I'll have to look at the Lear manual and see what they recommend using for anti-ice purposes. Sort of splitting hairs but nonetheless interesting...
