SWA Turbine PIC
What was said at the open house in June was basically the 1000 TPIC requirement was artificially low. The people they were hiring mainly had 1300 hours or greater. So, I wouldn't expect the requirement to go back down until demand exceeds supply. I have no idea when that would happen.
to get noticed you need closer to 1800 & the type
Actually you need current PIC time, the type, and a little luck. If you haven't logged PIC time in the last 3 years, you probably will not get called.
