SWA ontime performance #'s being questioned by DOT
  • Thread starter Thread starter flyguppy
  • Watchers Watchers 10
flyguppy
Do you guys have ACARS? Rumors of "calling the times in" seem to be clashing with the technology of today..........
Southwest on-time rate falls to less than 55% says data report
By Lewis Lazare Media/Marketing columnist Jan 6, 2011 6:17AM
ShareE-MailPrint
10-12-10 Southwest Airlines at Midway airport. photo by Jean Lachat/Sun-Times
Southwest Airlines’ on-time arrival performance took another huge hit in December, according to data released this week by Portland, Ore.-based Flightstats, a respected provided of airline performance data.
The grim news for the low-fare carrier came as the U.S. Department of Transportation asked Southwest Airlines to explain why the data independently collected by Flightstats has begun to diverge so markedly in recent months from the on-time statistics Southwest internally generates and provides each month to the DOT.
According to Flightstats, only 54.65 percent of Southwest planes arrived on time in December. “On time” is defined as arriving at the gate within 15 minutes of the scheduled time. In December Southwest was dead last in on-time arrival performance among the 42 largest domestic carriers Flightstats tracks each month, the first time in recent memory — perhaps ever — that Southwest has been at the very bottom of the list.
Even though bad weather was a major factor impacting on-time performance for many carriers in December, both United Airlines and American Airlines still got 82.61 percent and 80.47 percent of their flights respectively to the gate on time for the month, according to Flightstats.
Southwest spokeswoman Brandy King would not reveal the airline’s own internally generated on-time arrival data for December, but she did say it was “significantly” higher than the 54.65 percent Flightstats is reporting. There was also a significant discrepancy in the November numbers.
Southwest executives in recent months have repeatedly said they were at a loss to explain why the Flightstats data has suddenly begun to differ so markedly from the airline’s own statistics. But the carrier has conceded it is grappling with several big operational issues, including record load factors and a growing number of connecting passengers at airports such as Chicago’s Midway, where Southwest is by far the dominant airline.
Record load factors have made it tougher to deplane passengers and load outbound travelers in the 25 to 35 minutes Southwest typically allots for the process. And increasingly, outbound planes at airports such as Midway have been held for late-arriving connecting passengers. Getting connecting luggage to the right planes has been a struggle as well.
Southwest also recently announced new senior executives in both its operations and scheduling departments, two key areas directly involved in the airline’s on-time performance.
For the past several months, Flightstats has indicated it was eager to work with Southwest to figure out why its data has begun to differ so markedly from Southwest’s internal statistics. Flightstats did get a call from Southwest after the Department of Transportation said on Tuesday that it wanted an explanation. “Flightstats is pleased to be working with Southwest,” said spokeswoman Meara McLaughlin, adding “we only want to represent true, timely and accurate data about the airlines.”
Southwest Airlines On-Time Arrival Performance August through December 2010
Flightstats U.S. Department of Transportation
August 81.2% 82.3
September 78.50 86.3
October 65.48 77.9
November 66.56 not yet released
December 54.65 not yet released
ACAR's is the only "time" SWA uses. I wager that Flightstats is accurate, how SWA is coming in with a different number defies the facts. Seeing regular 45-60 minute turn times.
Wait a minute, you mean to say that SWA may not be playing by the rules?!?
<GASP>
They should be buying our Crews and Passengers pizza for the length of time we're sitting at the Gate these days.:rolleyes:
Ewr and atl should really help those numbers. I suppose they could always increase the scheduled block times significantly.
I have noticed that in the past week or two my FlightTracker app is not updating the delays.
Gup
If they do stretch out the scheduled block times to improve on time performance, how does it affect TFP system at all? Would it help/hurt or is it simply a paper number and not change your pay since mileage is same?
they won't stretch the block time...... they'll just increase the turn times. When I got hired it was 10 minutes. Now it's no uncommon to see a 35 minute scheduled turn.
Gup
My daughter flies home on SWA a lot and I've noticed they run late many of those times. When I commuted home through MDW last month, there were tons of late flights on the board with no real wx events anywhere.
SWA is a big airline now. They fly to big, congested airports. It's not the same SWA that used to load a -200 using the front airstairs while deplaning from the aft airstairs.
Increase turn times, pad the blocks a bit and watch aircraft utilization drop to be more in line with the "conventional" airlines. Just a fact of life.
SWA wasn't using witchcraft to make their operation work so well, they just operated within a certain "box" that no one else could (or would). Now, they have been steadily venturing outside their box and running into the same problems as everyone else.
TC
It's called "redefining excellence" and trying to squeeze out profit from all the low-hanging fruit through our system. Cutbacks to the point where the ground personel are pushing back...LAS, DEN, BWI, etc.. We have accountants running the system instead of operationally oriented leaders! Also, if you actually read the bios of some of the senior management and where they started in SWA, you see people who literally won the lottery and are protecting their positions at all cost. Their talent of looking pretty and kissing a$$ carried them along way from throwing bags and provisioning aircraft...MIT program and the theory you can train anyone to any level of competence! If they were given the option of "spending more time with the family" they couldn't get hired anywhere at their current management level and salary! Which of these leaders would stand up and point out to an accountants their excellent ideas may not float so well in an operationally-oriented business? Hence the ground delays leading to longer turn times and delayed flights...REDEFINING EXCELLENCE!
Yep...just like the rest of the airlines.
