SWA Asst. Dispatcher openings for external candidates
OPNLguy
It appears that the window for SWA assistant dispatcher openings for external candidates will open tomorrow, Tuesday, March 22nd, and be on the swa.com website at that time. No idea how long the window will be open, and reportedly four (4) will be hired.
Striketh whilst the iron is hot, folks, and good luck!
Anything specific to put on the resumes? Address or name of personnel, etc...
Anyone find the listing link.. does not seem to be listed on the SWA site at this time..
All the info I had said it would be posted on 3/22. I wish I could assume it would have been up at 12.01am or 08.01am, but neither was the case. ;)
I do see where they've already posted a MX intern position so far today, so I'd check back frequently throughout the day to see when the assistant dispatcher position goes up... ;)
https://www.swajobs.com/ci20/index....STATE.VALUE=PostingStates.TX&SOURCEINFO=Texas
Looks like we shut down the sytem.. error code when trying to process the app..
The site is experiencing technical difficulties.
Sorry for the inconvenience. Please retain the information below and forward to technical support.
Error ID: 43938761
I got in using the same link. If it doesn't work for you, try www.swa.com and hit it via the careers links...
ASSISTANT DISPATCHER - REQ #15043
Apply Now
Overview
Date Posted:
3/22/11
Job Code:
DP02
City:
Dallas
State:
TX
Country:
United States of America
Category:
Other
Job Type:
Regular
Description
WORK ACTIVITIES/CONTEXT:
Perform numerous duties that assist the Dispatchers, including but not limited to:
Execute ATC slot substitution programs and maintain various operational databases.
Transmit various notifications to the stations during daily operations and ensure that selected weather maps are faxed to stations for distribution to Flight Crews.
Maintain printed weather NOTAM and field condition information for archival purposes.
Maintain daily on-going dispatch bulletin.
Assist the Dispatch Specialists with all areas of SWA charter planning.
Must be able to meet any physical ability requirements listed on this description.
May perform other job duties as directed by Employee's Leaders.
Minimum Requirements
BASIC QUALIFICATIONS:
High School Diploma, GED or equivalent education required.
Must be at least 18 years of age.
Must have authorization to work in the United States as defined by the Immigration Reform Act of 1986.
QUALIFICATIONS AND REQUIREMENTS:
EDUCATION:
Must have a high school diploma or equivalency.
College course work or a degree preferred.
WORK EXPERIENCE:
Must have 3 years airline or related work experience with a 121-air carrier under the Code of Federal Regulation.
LICENSING / CERTIFICATION:
FAA Aircraft Dispatcher Certificate.
Must be a licensed Aircraft Dispatcher under Federal Guidelines.
PHYSICAL ABILITIES:
Ability to perform physical activities such as lifting (50 lbs), standing, sitting, writing, and speaking.
SKILLS/ABILITIES/KNOWLEDGE/WORK STYLE:
Must be able to comply with and enforce company attendance standards as described in labor agreements and/or established guidelines.
Must be able to operate various computer systems (current and emergent), including PCs & SWIFT (SGI hardware) with various software packages.
Must be able to type and/or use the computer keyboard with sufficient speed and accuracy to meet the current demands of the job.
Must have the ability to master any emergent computer systems that become available for use within the OCC.
Must be able to work well with others as part of a Team, professionally interact with other departments.
Must be able to work under tight time constraints and under stressful and/or emergency situations.
Must be able to use various radio equipment.
Must be able to communicate and receive information verbally via radio or multi-line telephone equipment.
Must be able to work rotating shifts (24x7) and overtime as required.
Must be able to comply with Company attendance standards as described in labor agreements and/or established guidelines.
OTHER QUALIFICATIONS
Must maintain a well-groomed appearance.
same result.. system error.. we shut them down.. guess 200 + dispatchers applying at the same time would do it..
More likely the 200,000 pilots applying online, since their window closes tomorrow on 3/23.
Keep trying... (and I got the link to work again....)
