jetlink130
Member
- Nov 1, 2004
You might want to post this on the SWAPA Forum or Southwest PPrune Forum. You would get a better response.jetlink130 said:I just started at SWA and have noticed that not much is geared for Mac users. If there are any SWA people that use Macs, I would luv some input.
FatesPawn said:I just bit the bullet and bought Virtual PC 7.0. That way I can run Moostro, Wbid, and Maestro. I never thought XP could be so SLOW though ;-) I guess my G5 just isn't up to snuff.
Sunnfun said:If you happen to know someone with a Windows 2000 CD, install that instead. It is much faster than XP; XP is so bloated with all that stuff running in the background. I'm running W2K on my 1 GHz iBook on VPC 6, and it is not bad at all. You having a G5 should run it even faster.
NuGuy said:Win 98 also works very well with VPC. If your software will support it, I would run 98 instead of XP.
OTOH, if you MUST use XP, go into the settings and turn down ALL the visuals and turn the sound off. Turn off/uninstall anything extra in the background. Zonealarm and Norton AV are both VERY bad resource hogs.
Sunnfun said:btw, can't wait for Mac OS X Tiger, gotta love an OS that actually gets faster with every new major release!![]()
YellowLab said:Went to the apple store online. Which virtual PC program should I get? I don't know the difference between each of them I'm not that savvy. I did see there was one virtual PC that is a Windows 2000. Is that the one I should get?
Sunnfun said:There's actually two parts to every VirtualPC Installation: The Virtual Machine and the Operating System or "Guest OS". You can buy VirtualPC with or without a Guest OS. If you already have a Windows CD from an earlier PC or something, you can use that and just buy VirtualPC without a Guest OS. You just create a virtual machine in VirtualPC and boot from your Windows Install CD and install Windows like you would on a "naked" PC. Don't forgot to install your extensions afterwards, those will enable printer access, usb access and so forth. It's all actually a lot easier when you do it.
Bottom Line: If you already have a Windows Install CD (Who doesn't...) then you don't need to buy one with Virtual PC.
FatesPawn said:While it was faster, Virtual PC 7 doesn't support "virtual printing" from within Win98. That means that it has to STEAL the usb printer from the MAC. ie. the printer CANNOT be used from within the Mac environment while VPC is running. No big deal. But, I has a REAL hard time installing drivers from within Win98 for my printer.
If you buy the all in one package complete with WinXP OS, you won't have this problem. VPC will emulate a printer from within XP and print through the mac software to your printer. It's a slow process so don't plan on doing much printing from Winxp unless you can get your printer drivers to work like I described above.
Sunnfun said:That's also true, but XP is just so painfully slow compared to Win2000 on a G4. I don't know how it is with a G5, but People report VPC7 to be somewhat slower VPC6 on G5s.
