I will bite....
I disagree strongly with Stream and the other poster for nothing more than the simple reason that a job can be lost if you are unsuccessful when making that call, may be your last line of communication with them. It is much more "personable" and "professional" to walk the resume in and meet with the appropriate people versus sending it via mail, fax, or email, etc. This will actually show the employer that you are that much more interested in the job than the other potential applicants. This will vary depending on the flight department and how "tight nit" they may be. Quite a few of the more popular 91 departments are nearly impossible to tap into unless you have inside help so either way it is probably a waste of time but it does not hurt to try.
Surplus has always exceeded demand in this type of flying and it has been my experience that most of these types of jobs are gotten by walking the resume in and meeting with the right people at the right times or having internal ties to get you in the door. Ask some of the corporate pilots in KLAS and the nascar pilots how they got in the door, surely not a very easy task.
You are not coming across as "unprofessional", you are simply showing that you have the desire and ambition to become part of a team. My former company would only hire guys that walked the resume in (or had a company pilot walk it in with a LOR attached). All resumes sent in via the mail, fax, email, etc, were all filed and never looked at again. They wanted to see the person went that extra step to show them how badly they actually wanted the job. These departments can be picky and most are. It does not matter if you are a relative of St. Peter, you will likely have much better luck walking it in. I personally have seen this happen many times and 95% of the time the outcome was usually "success" if the flight department was looking for pilots at that time. If they are not hiring atleast when you speak to the chief pilot he then can put a face with your resume and if you catch his attention then you may in fact get that magic phone call when the hiring resumes.
Do as you wish but I would walk it in to every flight department that is in your reach. I think the end result will be a favorable one if you do so.
use good taste and judgment and you should be fine...
call and ask if you can drop off a resume. You'll most likely find out who the person you need to talk to is, and when they will be in. Works pretty slick.
Negative, bad move.. Do you realize how many calls a given flight department receives daily/weekly pertaining to possible "employment"? m a n y - -... Most departments screen the calls and you can expect the standard reply " send us your resume and when we have an opening we will give you a call OR " we will get it to the right person"... Your response, "thanks".. Not a very good idea if you ask me. This will accomplish very little if anything.
3 5 0
