Static vs Rolling Takeoffs
getonit
I know all of the performance numbers, for the Citation 500's are based on static T/O's. Does anybody have any ballpark numbers of the performance hit if you do a rolling T/O? My simuflight and flightsafety manuals have some vague wording about more than adequate length, but no real guidelines.
Reason I am asking is, at my new job everybody does static T/O's on every runway and I am not a big fan of them, unless necessary.
Any opinions?
Static T/O's seem more orderly and methodical, allowing you more time to think and check for anything missed. Rolling departures can cause things to speed up and feel rushed. Never know if you'll need that extra margin of runway for an abort. The time afforded on the positioning can make a difference.
In Falcon 50 school they told us that unless you hold the brakes and set the power, that the DEECs won't let the engine provide advertised takeoff thrust for something like 3 minutes after you push up the thrust levers. Thus the reason to get on the runway and hold the brakes. Actually I'm confused. How does anybody actually do a "static" takeoff? Do you sit in the cockpit and make airplane noises or something? :) Just kidding...
EB
Static vs Rolling T/O
At our regional airline a rolling takeoff is the normal.
Static takeoff's are rare and only when performance dictates.
On that same thought reduced thrust takeoffs are also normal too.
There is nothing wrong with a rolling takeoff. If, you have enough runway.
However, as far as the FAA, aircraft manufactures and the insurance companies are concerned all takeoffs should be static power. In the real world, of course, one has to make rolling takeoffs at most major airports for traffic flow.
Come on, if your BFL on any given day is half or a third of the runway length available there is no reason not to make a rolling takeoff.
A little clue here, it is called "Situational Awareness"!
Just remember to brief it to your crew, both in the front and the back, if your going to do anything unusual.
We have a takeoff procedure at a Honuras airport that doesn't allow rolling takeoffs. Still getting the engines spooled up, releasing the brakes and going to takeoff power is a lot better than letting the plane shake at takeoff power before releasing the brakes with maybe 10 feet extra runway.
Some aircraft such as the Seneca have a caution about rolling takeoffs as centrifugal force on the fuel can unport a fuel pickup. Check your POH/AFM.
I think a FED with a burr under his saddle could conceivably come after someone for making a rolling takeoff for "careless and reckless operation" as there is no published takeoff data for such takeoffs. Each situation and pilot technique is different making it nigh on impossible to produce such data.
While a static takeoff will give you the manufacturers max performance numbers, there are some real advantages to a rolling takeoff.
First, when I say "rolling" that doesn't mean pushing the throttles up until aligned with the runway, it just means that the brakes aren't held while power is advanced. Taxi on, align like normal, then advance the power. The forward movement while power is advancing reduces stress on the engine (less chance of compressor stall as a result), reduces chance of FOD ingestion and is less wear on the airframe and brakes. The difference in actual runway useage is very small.
I just had a discussion about this on CAAM while preparing to learn a new airplane (C90B). I don't recall ever making but a few static TOs in the B200 and B58, most are rolling, and it made me uncomfortable at first. But the boss always allowed me to roll into perfect alignment before pushing up the power, even if someone else was on final. He says "You don't go till YOU'RE comfortable and the the other guy can just go around if he gets here too soon."
D.sanchez said:
This stupid woman with her goofy looking hair under her hat is, suprise, suprise, a UAL scab. (Check the U.S. master scab list) I hate these people that wear their captain hats/uniforms in pictures attached to their articles which make them sound like "experts."
What's it like looking way up a great big ladder full of stupid people and only seeing their butts?
The other thing about static takeoffs is when it's slippery, you could be more prone to sliding around.
Heres a question, is it easier to set power when you're static? Single pilot in a King Air I would think it would be somewhat difficult from a rolling start to stay centerlined, move the throttle levers forward and be watching the engine instruments at the same time.
Interesting comment. If I suspect the runway may be slippery I always make a static takeoff. If I cannot hold the plane with brakes, we don't go.
I'd rather find out the runway is slippery before I start the takeoff than when I'm racing down the runway and have to abort.
Alot of fighter type airplanes will slide forward on locked brakes at max power. Kinda tough to do a max power check and wipe out before T/O. I don't think any US fighter can still put in afterburner. Wet runway? forgeta'boutit.
It did take a bit of getting used to, especially considering that the power levers on the B200 I fly are not rigged symetrically (left must be 1/2 - 3/4 farther forward for symetrical power). But I am very, very low time and I got used to it, so for most full-time pros it wouldn't be an issue at all, I'd think. The Captains I tag along with all do it quite smoothly, with no thought whatsoever.
When I was going through recurrent on LR-35's, FlightSafety said you had to have at least 10% more than minimum required to do a rolling takeoff. I think they used the same figure for the 20's also. However, I never saw that in writing anywhere.
I my opinion, if you have enough time in the airplane that you're comfortable, and enough runway for the conditions that you feel safe, there's no reason not to use a rolling takeoff along with a reduced power setting. But, if anything happens, you better be able to stop or clear the obsticle. If not and you survive, there are going to be questions to answer. So, CYA.
EB
My understanding is that the 3 minutes is simply the number that the FAA chose to allow for certification...you can sit on the runway with the thrust levers full for 3 minutes before doing your certification takeoffs.
According to my SimCom Hawker book, "When using a rolling takeoff, reduce the available field length by 100 feet." IOW, plan on an extra 100 feet of ground roll. Not that big a deal on most runways.
I'm nowhere near the airplane now, so I can't actually verify that with AFM data, but I'm guessing it's a reasonable facsimile of something in the AFM performance section.
Fly safe!
David
I was thinking along the same lines, the BE99 I flew required us to parallel the torques at 400 ft/lbs a side before advancing to takeoff power. If you don't, you're more likely to have one side spool up faster and jerk you off the centerline.
You can do it on the roll, its not that hard if you're familiar with the plane, but I'd imagine you'd use more runway from the time spent rolling at low torque.
If this has any bearing on anything I believe that all AFM T/O numbers are based on the power being set by 80kts.
I think that may be an erroneous assumption...everything I've seen indicates power takeoff power set prior to brake release to make chart data.
From my SimCom Hawker book:
Associated conditions...
...Both engines are run up to initial maimum take-off power and then brakes are released....
Obviously, this isn't from the actual AFM, but I'm betting again that a reasonable facsimile exists in the AFM.
As far as the power being set by 80 knots, this is probably listed as a rolling start technique, but that's a technique that takes you away from performance chart data.
Fly safe!
David
Fly safe!
David
Ok, maybe my info just applies to a certain type.
Same with our B200. Not rigged symetrically. Sqwauked several times in the past years and never corrected perfectly. We now live with it. With experience and proficiency it is not a problem. Typically King Air pilots bring power up on the brakes until the props are on the govenors (2000 rpm) and then release and then push up power due to varying spool up times of the props/engines. If you are smooth there is no reason to have any variation and stay on centerline. If you jam them forward you will get unsymetrical power (and the amount of variation may change due to density altitude). This happened the other day to us with our other pilot flying and he aborted the take-off (rightfully so, but takes some explaining to the pax). He is thinking it was something wrong with the engines, but it was technique.
Our manual states that a rolling T/O has a negligible performance difference vs. a standard T/O.
In the 737, especially the NG aircraft, the intake lips are so low to the ground, I'm surprised they don't FOD more. We never jack the power up all the way unless we have some velocity, and especially on landing roll, you get out of reversers by 60 knots to avoid FOD unless stopping distance is critical.
As the other guys have said, it is AC specific, but I think the general gist is if the AC can handle it mechanically, a properly executed rolling TO doesn't hurt and I think is more comfortable for pax and easier on the jet.
