Ok I am getting ready for my CFI checkride and I am trying to explain stalls In a manner that is easy to understand. I know that an airplane will stall when the critical AOA is exceeded. But lets say I am cruising around in a 150 and pull the power....I keep pitching up and up and up and finally the plane stalls. Why is that pitch alot less than if I had full power in and then the plane stalled? I know that with full throttle there is excess power available, but I cant seem to bring everything together. I thought critical AOA on most light planes is about 18 degrees pitch up. I know that with idle power in the 150 the AOA is not even close to 18 degrees in the stall. Your ideas and thoughts are appreciated. Thanks!
