Spark plug torque on Denso IK27 spark plugs
I've been trying to find the proper torque to use on the Denso IK27 spark plugs in my Lycoming 363i from CubCrafters (essentially an IO-360). I read somewhere a year ago 15 ft-lbs and am trying to find my resource but also at the last condition inspection done as owner assisted the A&P also confirmed 15 ft-lbs. But I want to verify so if anyone knows the info please let me know.
I looked up the plug at the link below and in the specs it shows the torque values so I think 15-22 is correct. Also FYI they are 14mm plugs.
Torque SpecsCast Iron: 26-30 lb. ft. Aluminum: 15-22 lb. ft.
I do change the plugs every year, even with lean while taxiing and LOP while flying my plugs still looked like crap. For FX-3's like mine they are cheap at $10/plug. Amazon seems to be the best place to get them and I carry two spares in the plane as well.
Amazon product ASIN B000CIY4FM
Back to this topic on spark plug torque. CubCrafters recommends 15 ft-lbs which I think is too low. In my recent saga with Lightspeed coil packs I found that Lightspeed recommends 20 ft-lbs in their installation manual. I researched the Van's forum and seems the average is 19 ft-lbs. I have been using 18 ft-lbs.
What I also stumbled upon was discussion on using anti-seize or not. I found the Denso says NO to anti-seize as it can cause the plug to be over torqued. Interesting! I also read discussions of the same on the Van's forums. Anyone here have opinions on whether or not to use anti-seize?
