Sovereign vs. G150
White Feather said:
NGT -
Real men fly Falcons! :p
j/k - I know you....... ;)
Good luck with whatever you end up flying.
Gimme a call man... I'll buy the first round! :beer:
You Coast Guard wannabee!
Any hack can cross in a EX!(WS)
Real men ditch in the middle and paddle the rest!!
Cianamid and DD forever!!
"If the pilots are cryin, your a dyin"!!
LOL - its (BA). :nuts:
johnsonrod said:
That T/O distance is not very impressive for the G150. That might restrict the aircraft a bit from operating out of some airfields - something to consider. Sovereign also has more baggage space (probably not good for the pilots).
Gulfstream's website is now quoting 5,000 ft. for takeoff distance under SL/ISA/MTOW conditions. That's an improvement from some of the numbers that Gulfstream was trumpetting when they took the cabin mock-up around. I recall at one point, the quoted takeoff distance for SL/ISA/MTOW was around 5800 ft.
I wonder if the takeoff performance is limited by geomety - i.e. the maximum body angle to avoid ground contact during rotation. That might explain the long distance requirement. The thrust-to-weight ratio seems a bit low, too.
