Southwest bumped out of base?
wood pecker
Can a junior FO get a senior base such as MCO or BWI with the hopes of getting bumped out when the senior guys come over in the next 2 years?
The rumor or fact is that a pilot who gets bumped out has more options than a pilot that did not. So in training if everyone senior to you takes OAK or HOU because they want to avoid reserves in MCO and you get stuck with being on the bottom in MCO it is ok. The reason being all of the senior guys who will be coming over will bump you out of MCO giving you a better chance of getting ATL over a guy who didn't get bumped.
Did that make any sense?
Displacements usually go to what ever your seniority can hold..... If you get displaced from MCO, typically if you are senior to any ATL person, you can bump them... That's been my experience...
That busts that myth. Sounded too weird to be true but while studying I read there are close to 2,000 different things between the way both airlines operate the -700. That sounded too weird as well but it was verified by friend in ground school.
Once you're in a base, you cannot get bumped out by someone more senior, just because they decide that they want that base. You can ONLY get displaced out of a base if:
1) That base has a reduction in the number of pilots in your seat, and not enough pilots voluntarily bid out of the base during that period, or
2) A different base has a reduction, and a pilot more senior to you gets displaced out of it as in #1 above, and his next choice is YOUR base, and there's no growth in your base to accommodate him. In that case he goes to your base, and the bottom guy gets displaced out to HIS next choice. This is called a secondary displacement.
When there's any growth at all, neither of these things happen much. New guys typically go to the most junior base, and everyone else gets to move to a more desirable base (or have more people behind them). It's when there's absolutely no growth at all and the planners tweak schedules to move a few pilot numbers from base to base, that displacements happen more often. With six-plus-going-on-eight-thousand pilots, there's always a bunch of pilots, every month, who want to go to a different base than the one they're in, so that helps somewhat.
If you ARE displaced out of your base, you can either take a paid move (with all the financial benefits that come with that), or you can have the company reimburse you for one hotel room per pairing (or up to two hotel rooms per reserve pairing) for the first three months in your new base. At least I think it's three months; it may be more.
There is no "right of return" in our contract (although a lot of people would like it, and want the union to bargain for it), so if you DO get displaced out of a base, you don't have any special right in subsequent bid periods to get back ahead of anyone more senior to you who also wants it. That's pretty much why the "gamesmanship" that you spoke of will not help you keep or get to a more desirable base.
The bottom line is, that you should always bid what you really want. Always bid the bases in the order that you want them. Hope this helps.
Bubba
While this is technically accurate, lack of ROR effectively allows a senior guy to bump (or more accurately, keep) a displaced junior guy out of his base.
The difference is that it takes a vacancy bid or 2 to accomplish, but the end result is the same.
As much as I love this company, our vacancy bid system sucks for the junior folks and is in dire need of overhaul. We are not a 2 domicile, in the same state, airline anymore.
How do the more senior pilots feel about that? Who should get what they want, the more senior pilot or the more junior pilot? I'm just saying........that's how seniority works for pretty much everything in a union contract.
Unless you want to waste 30 seconds no need to read the following.
That was the best explanation I've seen. Thank you.
Your example is what I misunderstood earlier. What I thought was a junior pilot picks BWI first and ATL second and is the last guy in BWI.
MDW reduces by 1 and that displaced guy chose BWI as his 2nd choice so the last guy in BWI gets bumped out unless BWI grows. The bumped guy's 2nd choice is ATL so he would get rights into ATL out of seniority order because he got secondarily displaced.
I am a relatively senior guy, and have NO problem with ROR for a guy that bid, was awarded and moved to a domicile, and was then involuntarily displaced. The -3/+1 monthly vacancy bid is the real problem, IMHO. It really wreaks havoc on the QOL of our junior folks. ROR is industry standard, and for good reason.
If the junior guy could hold it, then the senior guy could too.
Are you guys considering smaller satellite bases in this round of negotiations. That would probably take some of the pressure off all the domeciles. Maybe TPA, STL, BNA etc. Aside from ATL how is SWA going to absorb 1700 AAI pilots in existing bases?
