TXCAP4228
- Sep 10, 2002
I haven't posted to FlightInfo in a long time, but I thought I would share this in case others want to make use of it in the future.
In the last couple of years I have obtained a couple of type ratings while working as a right seater at CAE Simuflite at DFW. Because these type checkrides were done in a Level C/D sim and because I did not have the requisite experience in turbojet aircraft (there are three or four ways to avoid having this limit applied, and they all involve having military or civilian experience either in the specific aircraft type or combined experience in turbojet aircraft), my certificate had a limitation on it saying "Pilot in Command Limitation applies to HS-125 and CE650". This language is the new way of saying what used to simply be "SOE 25". After getting my first type rating I started doing contract work in several Part 91 jets, and over time as I got comfortable with some of the captains I was flying with I told them about the SOE limitation and asked them if they wouldn’t mind signing off empty legs so that I could have it removed. What I asked the captains to do was to sign my logbook with “SOE Signoff, ATP# XXXXXXXX, [captain’s signature]”. Once I got the 25 hours signed off, I filled out an 8710 (only needed to fill out Part 1 – the top part). At the very top where all the checkboxes are, I marked “Other” and wrote “SOE REMOVAL”. I did not fill out anything in Part 2 or Part 3 on the front, and I did not fill out anything on the back. Then I took my logbook and the 8710 to the local FSDO Office (had to make an appointment), and I met with a FSDO Officer. I showed him the logbook entries and we chatted for a couple of minutes, and then he filled out the rest of my 8710 for me and gave me a new Temporary Airman Certificate with the limitation removed.
Incidentally, I had all of my SOE signoff’s done in Hawkers, but getting that done got the SOE removed from both type ratings. This makes logical sense considering the intent behind the SOE, but over the last couple of years I got different answers from everybody I asked about whether I would need SOE signoff’s for each specific aircraft type. As it turns out, the FSDO officer just removed the language altogether on the basis of the 25 SOE hours in the Hawker.
So, for anybody in the future who does a search for how to remove an SOE limitation from their certificate, this is how I did it and what to expect, and hopefully it will help you out.
One other quick note, at some point the SOE removal will transition to IACRA, but its not there yet so for now it still requires an 8710.
Best of luck to you!
