Flechas said:A slip
airpix said:During climbout with the wings level and no rudder, ball's pegged to the right, is the aircraft in a slip, skid or neither?
Skid is when the ball is outside opposite the direction of turn...I would also agree with Donsa320.
JB74 said:Correct, in a turn. I think to answer airpix's question, we need to know if the heading is decreasing, or constant.
Decreasing = skid
Constant = slip
Daveman said:Center the ball with rudder trim. If you ever fly the MU-2 this will become habit. One side on the climb, the other on descent.
So to answer your ? maybe it's a skip or a slid?
JB74 said:Yep, Airplane Flying Handbook p 4-5.
JB74 said:Good info Donsa320. Man you have flown everything![]()
Lets say that a 172 is climbing out with a 15kt crosswind, and you are holding constant heading with level wings (no crab angle, being blown to the left). How would the plane be coordinated then?
I have a feeling that is what airpix meant.
airpix said:No I'm just wondering what to tell the student on takeoff. Climbing out, wings are level, balls pegged to the right, headings constant. They won't use enough right rudder!! Are they skidding the plane or slipping it?
STEP ON THE BALL, THE PLANE'S IN A _______________?
airpix said:Is that chapter 4, page 5? I can't find it.
Donsa320 said:If Airpix convinces his student to counter the yaw in the climb with enough right rudder and finally gets the ball exactly in the center with the wings exactly level is the airplane then moving exactly straight through the air??
nosehair said:No, it is not. Think about the P-Factor. A single engine propeller airplane will not, repeat, NOT have the ball centered in a straight climb holding right rudder for a constant heading with the wings level. Center of thrust has moved to the right of center and would require a slight right wing down to counter this off-set thrust. Since we teach keeping the wings level and holding a constant heading, the ball will be slightly to the left. The airplane is slipping slightly to the left as a result of the off-center thrust. This is not very noticeable in small engine airplane at normal climb speeds, but it is there, and becomes more noticeable when practicing power-on stalls. Watch the ball slide about a half ball width out when holding a constant heading winds level when approaching a stall. If you try to keep the ball centered with the wings exactly level, you will yaw to the left.
In the figure 4-7, page 4-5 of the AFH, the picture depicting the wings level with the ball out to the right, this airplane might be in a climb (P-Factor) and correcting for yaw with aileron only, no rudder. (slipping)
Flechas said:Who cares, just fly the pane first, keep the ball in the center and stay out of the trees!!!!
Donsa320 said:You are right, I wrote too much....I musta got bit by the avbug! <bg>
~DC
Flechas said:I'd say slip because you don't have enough rudder, too much rudder is a skid.
Donsa320 said:The WIND has no effect on what the ball instrument is displaying.
~DC
