AviaNation
- Jan 9, 2004
- Total Time
- 5000
YOU MUST BE WILLING TO RELOCATE to any of our 16 domiciles which consist of Salt Lake City, UT, Portland, OR, Chicago, IL, Tucson, AZ, Denver, CO, Colorado Springs, Co, San Diego/Carlsbad, CA (co-domicile), San Luis Obispo/Santa Maria, CA (co-domicile), Fresno, CA, Monterey, CA, Palm Springs, CA, Sacramento, CA, Santa Barbara, CA, Los Angeles, CA, San Francisco, CA, Milwaukee, WI. You will be assigned a domicile upon graduation of Initial New Hire training. Domicile assignments are based on the operational need of SkyWest so you may be asked to relocate to a different area initially even if you currently live in one of our 16 domiciles.
College Courses or a degree as well as previous customer service experience is preferred. A High School diploma or a GED is required.
The FAA requires FBI fingerprinting for all applicants being considered for a crewmember position. If you have been convicted of a criminal misdemeanor or felony within the last five years you are not eligible for a crewmember position due to Canadian Immigration Regulations. If the conviction was between the last five to ten years or if you have had more than one conviction than you must complete the Canadian Criminal Rehabilitation process prior to being considered for the position.
You need to meet our minimum age requirement of 21 years of age at the time of interview. We have no age limit!
Your height must be between 5'0 and 5'8 without shoes due to the internal size of our aircraft. For your safety, there are no exceptions to this requirement. Your height will be verified at the time of interview.
Your vision should not exceed 20/40 corrected.
You should possess the confidence and excellent decision making skills needed to provide leadership and direction to the passengers.You may be the only Flight Attendant on some Flights so it is important that you are able to work alone as well as with another flight Attendant.You must be able to perform all required job duties and have the mental capacity to follow instructions and read documents.
The Flight Attendant position requires you to be physically fit. You will be standing, reaching overhead, walking, pushing, pulling and stooping for long periods of duration. You wil be given a physical agility test on your first day of training to ensure that you meet our general lifting and back strength requirements and have the ability to lift 45 lbs.
Your weight should be of such proportion to height that a professional appearance is maintained and the physical agility to perform all job functions is not hindered. The ability to walk and fit comfortably down the aircraft aisle while facing forward, fit quickly through the over wing exit and sit in the Flight Attendant jumpseat without modification or a seatbelt extension is required.
SkyWest operates flights 365 days per year which will require you to work a rotating schedule with variable hours that include holidays and weekends. You need to have the stamina required to work up to 14 hours per day with frequent change in climate and weather conditions. The Flight Attendant position requires travel on a constant basis with exposure to air turbulence, dry air, varying noise levels from aircraft engines and working in confined spaces.
You need to have excellent communication skills with the ability to converse with the passengers and deliver the onboard announcements in a clear, polished and professional manner in English.
You will be responsible for the internal cleaning of the aircraft after each flight as well as following the required guidelines for stocking and maintaining the aircraft galley and lavatories..
If you have been furloughed from another airline and should you be hired at SkyWest, you will be required to submit a letter of resignation to your current airline employer as well as to the SkyWest Airlines Training Department. SkyWest will confirm resignation with the prior airline.
You are required to have a current and valid passport with the ability to travel freely in and out of Canada and Mexico.
The offer of employment is contingent upon successful completion of FBI fingerprints/background results, physical agility test, and training.
FLIGHT ATTENDANT ORIENTATION AND GROUP INTERVIEW SCHEDULE
To apply for a Flight Attendant position please CLICK HERE and complete an ONLINE APPLICATION. For all group interviews please bring a copy of your resume.
--DOORS CLOSE PROMPTLY ACCORDING TO THE STARTING TIME POSTED FOR EACH INTERVIEW--
All Group Interviews are subject to time and location changes. Please check back periodically for confirmation.
LOCATION TIME / ADDRESS
ALBANY, NY
Thu. September 13th - 5 PM
Holiday Inn Turf 205 Wolf Road Albany, NY 12205
ALBUQUERQUE, NM
Tue. September 11th - 5 PM
Courtyard Albuquerque Airport 1920 Yale Blvd Albuquerque, NM 87106
ATLANTA, GA
Tue. September 18th - 5 PM
The Westin Atlanta Airport 4736 Best Road Atlanta, GA 30337
CHARLOTTE, NC
Thu. September 27th - 5 PM
Sheraton Charlotte Airport Hotel 3315 Scott Futrell Drive Charlotte, NC 28208
CHICAGO, IL
Wed. September 12th - 5 PM
Sat. September 22nd - 10 AM
Tue. September 25th - 5 PM
Wyndham O'Hare Hotel 6810 N. Mannheim Road Rosemont, IL 60018
CINCINNATI, OH
Hilton Cincinnati Airport 7373 Turfway Road Florence, KY 41042
COLORADO SPRINGS, CO
Radisson Colorado Springs Airport Hotel 1645 North Newport Road Colorado Springs, CO 80916
COLUMBUS, OH
Wed. September 19th - 5 PM
Clarion Hotel & Suites 900 E. Dublin Granville Road Columbus, OH 43229
DALLAS, TX
Country Inn & Suites 2000 Hard Rock Road Iriving, TX 75061
DENVER, CO
Sat. September 8th - 10 AM
Doubletree Hotel Denver 3203 Wed.
September 26th - 5 PM
Hilton Garden Inn 16475 East 40th Circle Aurora, CO 80011
EL PASO, TX
Mon. September 10th - 5 PM
El Paso Marriott 1600 Airway Blvd El Paso, TX 79925
FRESNO, CA
Thu. September 20th - 5 PM
Holiday Inn Fresno Airport 5090 E. Clinton Way Fresno, CA 93727
GRAND RAPIDS, MI
Comfort Inn 4155 28th Street SE Grand Rapids, MI
HOUSTON, TX
Mon. September 17th - 5 PM
Marriott Houston Intercontinental 18700 John F. Kennedy Blvd Houston, TX 77032
LITTLE ROCK, AR
La Quinta Little Rock Downtown 617 South Broadway Little Rock, AR 72201
LOS ANGELES, CA
Sat. September 29th - 10 AM
Crowne Plaza Los Angeles Airport 5985 West Century Blvd Los Angeles, CA 90045
MILWAUKEE, WI
Radisson Hotel Milwaukee Airport 6331 S. 13th Street Milwaukee, WI 53221
MINNEAPOLIS, MN
Minneapolis Airport Marriott Bloomington 2020 American Blvd East Bloomington, MN 55425
MISSOULA, MT
Holiday Inn Downtown at the Park 200 South Pattee Street Missoula, MT 59802
NEW YORK CITY, NY
Holiday Inn JFK Airport 144-02 135th Avenue Jamaica, NY 11436
ORLANDO, FL
Fri. September 28th - 5 PM
Courtyard Orlando Airport 7155 North Frontage Road Orlando, FL 32812
PENSACOLA, FL
Wed. September 26th - 5 PM
Homewood Suites by Hilton 5049 Corporate Woods Drive Pensacola, FL 32504
PHOENIX, AZ
Radisson Phoenix Airport Hotel 3333 East University Drive Phoenix, AZ 85034
PITTSBURGH, PA
Hampton Inn 8514 University Blvd Coraopolis, PA 15108
PORTLAND, OR
Sheraton Portland Airport Hotel 8235 NE Airport Way Portland, OR 97220
SACRAMENTO, CA
Residence Inn Sacramento Airport Hotel 2410 West El Camino Avenue Sacramento, CA 95833
SALT LAKE CITY, UT
SkyWest Hangar 1129 North 3950 West Salt Lake City, UT 84116
SAN DIEGO, CA
Holiday Inn Express Old Town 3900 Old Town Avenue San Diego, CA 92110
SAN FRANCISCO, CA
Hyatt Regency San Francisco Airport 1333 Bayshore Highway Burlingame, CA 94010
SANTA ANA, CA
Holiday Inn Orange County Airport 2726 South Grand Avenue Santa Ana, CA 92705
SEATTLE, WA
Clarion Hotel SeaTac 3000 S. 176th Street Seattle, WA 98188
SPOKANE, WA
Doubletree Spokane City Center 322 N. Spokane Falls Court Spokane, WA 99201
TAMPA, FL
Marriott Tampa Westshore 1001 N. Westshore Blvd Tampa, FL 33607
TUCSON, AZ
SkyWest Operations Building 2110 East Airport Drive Tucson, AZ 85706
If you would like to apply for the Flight Attendant position please submit an online application and attend a group interview. You may choose any group interview that works with your schedule and location from the recruitment events listed above. If you do not see a recruitment event scheduled in your area and you live in the Continental United States, please e-mail us at farecruitment@skywest.com to suggest your town as a future group interview location.
posted by:
Tim Kirkwood, Author
THE FLIGHT ATTENDANT JOB FINDER & CAREER GUIDE
http://www.FlightAttendantCareerGuide.com
LOOKING FOR AVIATION EMPLOYMENT? Go to http://www.AviaNation.com and post your resume for FREE. Job postings for all segments of aviation can be found on the site as well. Just click on this hyperlink or copy it to your web browser: http://www.AviaNation.com
ALBANY, NY
ALBUQUERQUE, NM
ATLANTA, GA
CHARLOTTE, NC
CHICAGO, IL
CINCINNATI, OH
COLUMBUS, OH
DALLAS, TX
DENVER, CO
EL PASO, TX
FRESNO, CA
GRAND RAPIDS, MI
HOUSTON, TX
LITTLE ROCK, AR
LOS ANGELES, CA
MILWAUKEE, WI
MINNEAPOLIS, MN
MISSOULA, MT
NEW YORK CITY, NY
ORLANDO, FL
PENSACOLA, FL
PHOENIX, AZ
PITTSBURGH, PA
PORTLAND, OR
SACRAMENTO, CA
SALT LAKE CITY, UT
SAN DIEGO, CA
SAN FRANCISCO, CA
SANTA ANA, CA
SEATTLE, WA
SPOKANE, WA
TAMPA, FL
TUCSON, AZ
posted by:
