SkyWest Airlines Flight Attendant open houses through July
AviaNation
Position: Flight Attendant (July Interview Dates)
Description: YOU MUST BE WILLING TO RELOCATE to any of our 16 domiciles which consist of Salt Lake City, UT, Portland, OR, Chicago, IL, Tucson, AZ, Denver, CO, Colorado Springs, Co, San Diego/Carlsbad, CA (co-domicile), San Luis Obispo/Santa Maria, CA (co-domicile), Fresno, CA, Monterey, CA, Palm Springs, CA, Sacramento, CA, Santa Barbara, CA, Los Angeles, CA, San Francisco, CA, Milwaukee, WI. You will be assigned a domicile upon graduation of Initial New Hire training. Domicile assignments are based on the operational need of SkyWest so you may be asked to relocate to a different area initially even if you currently live in one of our 16 domiciles.
College Courses or a degree as well as previous customer service experience is preferred. A High School diploma or a GED is required.
The FAA requires FBI fingerprinting for all applicants being considered for a crewmember position. If you have been convicted of a criminal misdemeanor or felony within the last five years you are not eligible for a crewmember position due to Canadian Immigration Regulations. If the conviction was between the last five to ten years or if you have had more than one conviction than you must complete the Canadian Criminal Rehabilitation process prior to being considered for the position.
You need to meet our minimum age requirement of 21 years of age at the time of interview. We have no age limit!
Your height must be between 5'0 and 5'8 without shoes due to the internal size of our aircraft. For your safety, there are no exceptions to this requirement. Your height will be verified at the time of interview.
Your vision should not exceed 20/40 corrected.
You should possess the confidence and excellent decision making skills needed to provide leadership and direction to the passengers.You may be the only Flight Attendant on some Flights so it is important that you are able to work alone as well as with another flight Attendant.You must be able to perform all required job duties and have the mental capacity to follow instructions and read documents.
The Flight Attendant position requires you to be physically fit. You will be standing, reaching overhead, walking, pushing, pulling and stooping for long periods of duration. You wil be given a physical agility test on your first day of training to ensure that you meet our general lifting and back strength requirements and have the ability to lift 45 lbs.
Your weight should be of such proportion to height that a professional appearance is maintained and the physical agility to perform all job functions is not hindered. The ability to walk and fit comfortably down the aircraft aisle while facing forward, fit quickly through the over wing exit and sit in the Flight Attendant jumpseat without modification or a seatbelt extension is required.
SkyWest operates flights 365 days per year which will require you to work a rotating schedule with variable hours that include holidays and weekends. You need to have the stamina required to work up to 14 hours per day with frequent change in climate and weather conditions. The Flight Attendant position requires travel on a constant basis with exposure to air turbulence, dry air, varying noise levels from aircraft engines and working in confined spaces.
You need to have excellent communication skills with the ability to converse with the passengers and deliver the onboard announcements in a clear, polished and professional manner in English.
You will be responsible for the internal cleaning of the aircraft after each flight as well as following the required guidelines for stocking and maintaining the aircraft galley and lavatories..
If you have been furloughed from another airline and should you be hired at SkyWest, you will be required to submit a letter of resignation to your current airline employer as well as to the SkyWest Airlines Training Department. SkyWest will confirm resignation with the prior airline.
You are required to have a current and valid passport with the ability to travel freely in and out of Canada and Mexico.
The offer of employment is contingent upon successful completion of FBI fingerprints/background results, physical agility test, and training.
FLIGHT ATTENDANT ORIENTATION AND GROUP INTERVIEW SCHEDULE
To apply for a Flight Attendant position please CLICK HERE and complete an ONLINE APPLICATION. For all group interviews please bring a copy of your resume.
--DOORS CLOSE PROMPTLY ACCORDING TO THE STARTING TIME POSTED FOR EACH INTERVIEW--
All Group Interviews are subject to time and location changes. Please check back periodically for confirmation.
LOCATION TIME / ADDRESS
ATLANTA, GA
Tue. July 24th - 5 PM
The Westin Atlanta Airport 4736 Best Road Atlanta, GA 30337
AUSTIN, TX
Mon. July 30th - 5 PM
Hilton Austin Airport 9515 Hotel Drive Austin, TX 78719
BOISE, ID
Tue. July 10th - 5 PM
Springhill Suites by Marriott 424 East Park Center Blvd Boise, ID 83706
CHARLOTTE, NC
Thu. July 26th - 5 PM
Sheraton Charlotte Airport Hotle 3315 Scott Futrell Drive Charlotte, NC 28208
CHICAGO, IL
Mon. July 2nd - 6 PM
Wed. July 18th - 6 PM
Mon. July 30th - 6 PM
Chicago Marriott O'Hare 8535 West Higgins Rd Chicago, IL 60631
CINCINNATI, OH
Mon. July 23rd - 5 PM
Hilton Cincinnati Airport 7373 Turfway Road Florence, KY 41042
CLEVELAND, OH
Sheraton Cleveland Airport Hotel 5300 Riverside Drive Cleveland, OH 44135
COLORADO SPRINGS, CO
Thu. July 19th - 5 PM
Doubletree Hotel 1775 E Cheyenne Mountain Blvd Colorado Springs, CO 80906
DALLAS/ FORT WORTH , TX
Tue. July 17th - 5 PM
Country Inn and Suites 2000 Hard Rock Rd Iriving, TX 75061
DENVER, CO
Mon. July 2nd - 5 PM
Sat. July 14th - 10 AM
Wed. July 18th - 5 PM
Doubletree Hotel Denver 3203 Quebec Street Denver, CO 80207
DETROIT, MI
The Metropolitan Hotel 31500 Wick Road Romulus, MI 48174
FRESNO, CA
Mon. July 9th - 5 PM
Holiday Inn Fresno Airport 5090 East Clinton Fresno, CA 93727
HOUSTON, TX
Thu. July 5th - 5 PM
Marriott Houston 18700 John F. Kennedy Blvd. Houston, TX 77032
LOS ANGELES, CA
Sat. July 21st - 10 AM
Wed. July 25th - 5 PM
Crowne Plaza Los Angeles Airport 5958 West Century Boulevard Los Angeles, CA 90045
MEDFORD, OR
Mon. July 16th - 5 PM
Red Lion Hotel 200 N. Riverside Ave Medford, OR 58111
MIAMI, FL
Embassy Suites Miami Airport 3974 NW South River Drive Miami, FL 33142
MILWAUKEE, WI
Tue. July 31st - 5 PM
Radisson Hotel MKE Airport 6331 South 13th Street Milwaukee, WI 53221
MINNEAPOLIS, MN
Minneapolis Airport Marriott 2020 American Blvd East Bloomington, MN 55425
MISSOULA, MT
Holiday Inn - Parkside 200 South Pattee Street Missoula, MT 59802
NASHVILLE, TN
Doubletree Guest Suites 2424 Atrium Way Nashville, TN 37214
NEW YORK, NY
Wed. July 11th - 5 PM
Holiday Inn JFK Airport 144-02 135th Ave Jamaica, NY 11436-1831
OMAHA, NE
Doubletree Hotel 1616 Dodge Street Omaha, NE 68102
ONTARIO, CA
Country Side Suites 204 North Vineyard Onatario, CA 91764
PHILADELPHIA, PA
Four Points by Sheraton 4101 Island Avenue Philadelphia, PA 19153
PORTLAND, OR
Holiday Inn Airport 8439 NE Columbia Blvd Portland, OR 97220
SACRAMENTO, CA
Residence Inn Sacramento Airport 2410 West El Camino Ave Sacramento, CA 95833
SALT LAKE CITY, UT
Sat. July 28th - 10 AM
SkyWest Hangar 1129 N. 3950 W. Salt Lake City, UT 84116
SAN ANTONIO, TX
The Westin Riverwalk 420 West Market Street San Antonio, TX 78205
SAN DIEGO, CA
Holiday Inn Express Old Town 3900 Old Town Avenue San Diego, CA 92110
SAN FRANCISCO, CA
Hyatt Regency 1333 Bayshore Hwy Burlingham, CA 94010
SEATTLE, WA
Holiday Inn SeaTac Airport 17338 International Blvd Seatac, WA 98188
SPOKANE, WA
Doubletree Hotel City Center 322 N. Spokane Falls Court Spokane, WA 99201
WASHINGTON DC, MD
Thu. July 12th - 5 PM
Holiday Inn Dulles 1000 Sully Road Dulles, VA 20166
If you would like to apply for the Flight Attendant position please submit an online application and attend a group interview. You may choose any group interview that works with your schedule and location from the recruitment events listed above. If you do not see a recruitment event scheduled in your area and you live in the Continental United States, please e-mail us at farecruitment@skywest.com to suggest your town as a future group interview location.
posted by:
Tim Kirkwood, Author
THE FLIGHT ATTENDANT JOB FINDER & CAREER GUIDE
http://www.FlightAttendantCareerGuide.com
LOOKING FOR AVIATION EMPLOYMENT? Go to http://www.AviaNation.com and post your resume for FREE. Job postings for all segments of aviation can be found on the site as well. Just click on this hyperlink or copy it to your web browser: http://www.AviaNation.com
