Sirius XM issue on Garmin G3X
kshunz
Cub Crafters FX-3, Cessna 182R
S50
Commercial SEL, SES, Instrument, and CFI
I have an odd issue with the XM audio from my Garmin G3X. This is in a Cub Crafters FX-3, delivered about 5 months ago. From the start, there was no audio at all. Last week I took it back to Yakima, where they found and corrected a bad connector. But on the flight home, I realized that only a few of the channels actually work -- most of them are silent. Channels 1-12 work, and a couple others like 15 and 17. All of the channels I tried above 20 were silent.
Hard to believe this could be a hardware issue. Any ideas?
Have you tried sending a signal to re-activate it? Although typically if not activated you'd only get channel 1. I realize CC should have given you a 3 month free trial activation but you may want to subscribe, if you haven't already, and check the plan.
Another option to check is look up from under the panel at the back right of the G3X - right as if you're flying. There are two BNC connectors, one of those is the SiriusXM connector. Make sure they are secure. You should be able to do so without removing the GDU.
I picked up a new FX-3 and just got it home. I had to send a refresh signal to it and I see the channel listing but none of the channels are playing audio. Let me know if you find a fix.
Likewise, I had no XM audio even though the channels showed up fine. I took it back to Cub Crafters and they fixed it -- I got the impression that they found multiple problems with the wiring.
But then I had the situation reported above, where only some of the channels worked. After I tried multiple refreshes, I called Sirius. They said something like "OK, try it now" and it has worked perfectly since then.
I think I'll start with last and call Sirius XM. I don't know that there is much to it other than connect the radio to the G3X which is a simple twist on BNC connector. Will report back. I don't plan to renew Sirius XM as I never use it and would just use bluetooth to my phone if I want music. I just want to make sure it's working.
Follow up: as discussed with SiriusXM we let the trial expire and now that I’m subscribed to both music and weather all is working perfect.
NEAL...
i got a g3x touch in my vl3 .....
can i activate sirius xm weather direcly on g3x with subscription or i need a gdl51-52 or any other satelite receiver ....
my question is , does g3x have built in satelite receiver?
The G3X Touch PFD model used by default by Cub Crafters contains an internal SiriusXM receiver and if you make sure that you have the external SiriusXM antenna connected, then you just need to call SiriusXM Aviation on the phone and then try and convince the person at the other end of the phone that you have a plane not a car. Eventually, you can get one of the aviation packages enabled (I have the VFR weather only Pilot Express) and after a power cycle of the G3X Touch and a “refresh” trigger from your SiriusXM web account, you will have working weather.
